Old 07-19-2011, 11:00 PM   #1
How can I prevent silverfish in the expansion gaps of laminate flooring
We have taken out most of our carpets and put in laminate flooring.
I still notice a lot of silverfish coming out from under the base boards.
We have just put in laminate into another room.
I am wondering what to do to prevent the fore-mentioned problem.
Is there any sealer that stays flexible to be put into the expansion gap between the laminate and the drywall?
Would Borax powder be appropriate or Baking Powder to discourage these pests?
Looking forward to your answers and experiences before we put up the base boards.
Thank you.
Cool HOME is offline   Reply With Quote
Old 07-19-2011, 11:02 PM   #2
Tileguy
Bud Cline's Avatar
Have you thought of calling an exterminator?
Old 07-19-2011, 11:59 PM   #3
jules4's Avatar
Sprinkle a thin line of diatomaceous earth around the base board and in any other problem areas, that will wipe out the silverfish (and anything else with an exoskeleton). Reapply after vacuuming/sweeping/washing floors.
Diatomaceous earth is totally non-toxic, it's just crushed diatom shells, so completely safe around pets/babies/etc.
jules4 is offline   Reply With Quote
Old 07-21-2011, 12:48 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Does it work on roaches?
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 07-23-2011, 06:13 PM   #5
jules4's Avatar
You bet - works on just about all the creepy crawlies (only limitation is the bugs have to come into contact with it for it affect them, and it has to kept dry).
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Laminate flooring to concrete abndaddy1994 Flooring 2 02-06-2010 09:26 PM
laminate flooring on top of tile newhomeowner808 Flooring 3 09-19-2009 08:34 PM
Question about laminate flooring jwemt81 Flooring 8 05-11-2009 01:09 PM
Question about mills on laminate flooring cpsilo1 Flooring 3 07-25-2005 01:05 PM
