| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Set Front Sag for Mountain Bikes
by Expert Village
All right, so the first step to making sure your suspension is properly setup is setting the amount of sag that you have. Sag is the amount of suspension that you're using, just static at rest. The proper way to really get a good measurement of sag, is... Read More »
How to Install Girders for a Deck
by eHow.com
A deck can beautify any home and increase the home's value. Like a house, a deck that isn't on a solid foundation is a dangerous thing. Be sure to build a solid deck by correctly installing the deck girders. This can be done in the following manner. Read More »
How to Transform a Closet into a Laundry Chute
by eHow.com
In bi-level houses, transporting soiled laundry downstairs wastes considerable effort. A simple solution is to transform a closet into a laundry chute. There's no need to give up an entire closet; a small addition against one wall can be an effective... Read More »
Setting the Center Pole for a Spiral Staircase
by Expert Village
Hi! This is Weldon Moon on behalf of Expertvillage.com. And the next step in building the spiral is to attach the pole to a fork plate. We have attached in the center of this plate. Then drilled in with a hammer drill, anchored these anchors into the... Read More »
How to Install Patio Overhead Rafters
by eHow.com
The rafters of a patio overhead serve two main purposes. They're meant to firmly hold the overhead in place, and they're meant to add decoration to your patio. Patio overhead rafters are moderately easy to assemble and install. Read More »
