-   -   How big of a gap in hardie board can I fill with thinset? (http://www.diychatroom.com/f5/how-big-gap-hardie-board-can-i-fill-thinset-37604/)
Constant Improvement 02-04-2009 12:08 PM
I am putting porcelan tile down in my bathroom, and have cut the .5" hardie backer and laid it down in the room. I left a 1/8" to 1/4" space around the perimeter and between the boards like the instruction said, but in the door frame where I cut the hardwood floor up, there is a gap about 1-1.5" between the hardie board and the hardwood. can I just fill this little gap with thinset when I cement the hardie board down or do I need to cut a little sliver of hardie board to go in there?
I mean... cement thinset is pretty much the same at cement backer board right? theoretically, you could just pour a .5" thick layer of thinset on teh subfloor to put your tile on.
-Eric
onlinehandyman 02-04-2009 06:01 PM
I have done thinset in very small places like that and it has worked just fine. I have even done grout like that where it's too small to cut a tile and it worked just fine. You would think that it would crack, but it doesn't. Good Luck!
onlinehandyman 02-04-2009 06:18 PM
Constant Improvement 02-05-2009 06:46 AM
Thanks for the reply... thats what I was hoping
my drill battery dies last night, and I only got one sheet of hardie board down, but tonight I plan on finishing it.
After re-reading my original post I thought I would clarify one thing: the gap is around 1" to 1.5" wide but it the entire length of the door frame (28"), so about 30-40 square inched total... dont know if it makes a difference.
Thanks,
Eric
angus242 02-05-2009 09:41 AM
I disagree. Just spend the time to put a piece of CBU in the gap. Thinset likes to shrink when it cures. I'm not comfortable with anything over 1/2" thick.
If you attempt this, 2 things might happen:
1. The thinset will shrink and you'll lose bond to the tile
2. The thinset will remain bonded to the tile but pull the tile with it and SNAP
For a gap that large, just add the CBU.
Constant Improvement 02-05-2009 09:49 AM
OK... I'm glad I asked the question then. If there is any concern at all, I might as well just do it then (not like its that hard). I just wasent sure whether having a sliver of hardie board that thin, or an area of thinset that thick, would be worse...
Termite 02-05-2009 09:49 AM
I'm with Angus 100% on this. You should cut a narrow strip of backerboard and set the backerboard strip in thinset as required, then screw or nail it down.
Constant Improvement 02-05-2009 09:52 AM
check... thanks guys.
homedude 03-21-2011 06:43 PM
This is why I love mud set
