How To Adhere This Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 12-28-2013, 11:35 AM   #1
Rewards Points: 874
We need to lay a few more tiles. As you can see we have a copper heating pipe we need to go over. We insulated the bottoms half but can cover it on the top as the covering will come above the concrete. Can we spread adhesive right over e pipe or will it cause a reaction with the copper? What can we spread over it. Thanks. Btw--doggie got in the way the forts time but had to post it anyway.
Also we are going to clean out all the debris by the pipe.
How to adhere this tile-image-4199862055.jpg   How to adhere this tile-image-4144325286.jpg
Mstrlucky74 is offline   Reply With Quote
Old 12-28-2013, 11:22 PM   #2
Rewards Points: 109
Silicone does not react with copper, it is safe and will even protect it from other materials. Get a tube if 100% silicone and fill the gap smooth then you can concrete and tile over it.
Olcrazy1 is offline   Reply With Quote
The Following User Says Thank You to Olcrazy1 For This Useful Post:
oh'mike (12-29-2013)
Old 12-29-2013, 03:54 PM   #3
Rewards Points: 874
Thanks... Won't the heat from the pipe melt the silicon??
Old 12-29-2013, 04:34 PM   #4
Rewards Points: 109
No, pure 100% silicone is good up to 400 deg F and your pipe should never see that high of a temp. Silicone is used to seal around fireplace exhaust vents with no issue and that's much hotter then what you are looking at
Mstrlucky74 (12-29-2013)
Old 02-21-2014, 08:09 PM   #5
Rewards Points: 874
Hello guys. I put the silicone around the pipe and now I am ready to lay the tile. What adhesive is best? Thinset etc. ...It is a slate tile. Thanks a a lot.
Old 02-22-2014, 06:53 AM   #6
Rewards Points: 109
Your call on that, everyone has different preferences. If my choice and the area is indoors and mostly dry I would use mastic. It spreads easy and comes premixed. If outdoors or in wet area like bathroom then thinset is good. Most will say thinset all the way.
Old 02-22-2014, 08:17 AM   #7
Rewards Points: 874
Thanks...wasn't sure you had to use a specific product when using slate tiles....it going on concrete slab as we'll so maybe that makes a difference
Old 02-22-2014, 11:32 AM   #8
Tileguy
JazMan's Avatar
Rewards Points: 226
Oh, and which mastic would you use to install slate on concrete?
That's because it's the right answer.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
rusty baker (02-22-2014)
Old 02-22-2014, 02:32 PM   #9
Rewards Points: 874
Well I used mastic for 2 tiles. Had to buy more but I switched to thinset ...hope the two tiles are ok with mastic ....
Old 02-22-2014, 03:00 PM   #10
Tileguy
JazMan's Avatar
Rewards Points: 226
What does it say on the label?
Jaz
Old 02-22-2014, 04:00 PM   #11
Rewards Points: 874
[QUOTE="JazMan"] What does it say on the label? Jaz[/QUOTE
Says tile is fine
Old 02-22-2014, 04:06 PM   #12
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
How would the tiles be flat to each other with mastic under some and thinset under some?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 02-22-2014, 04:26 PM   #13
Tileguy
JazMan's Avatar
Rewards Points: 226
Says tile is fine
LOL, too funny!
Jaz
Old 02-22-2014, 04:56 PM   #14
Rewards Points: 109
As long as they are level they will be fine. Report back in 30 years and let jazman know how they both held up the same
Old 02-22-2014, 09:42 PM   #15
Rewards Points: 874
Originally Posted by JazMan
LOL, too funny! Jaz
Really...that's your response
Need advice in fixing "contractor's" botched shower floor tile job toocheaptohire Tiling, ceramics, marble 5 10-15-2012 03:31 PM
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Tile over Painted Lightweight Cement New_2_DIY Flooring 16 08-28-2011 03:29 AM
Vertical tile on wall poolecw Flooring 2 06-01-2010 11:05 AM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
