How To Add Carpet Treads To Hardwood Stairs - Flooring - DIY Chatroom Home Improvement Forum
Old 02-06-2012, 01:27 PM   #1
How to add carpet treads to hardwood stairs
I'm looking for an inexpensive way to add carpet treads to my stairs so me and my old dog can go up and down my stairs safer...we keep slipping on the hardwood. I don't want a long runner, just carpet on the treads. Browsing on line I found that everything is super expensive, like $10.00 or more for each tread x 15 treads =$150.00, which is too expensive. Does anyone have ideas for a more affordable solution? Also, will the adhesive backing ruin my beautiful stairs?
-Jade- is offline   Reply With Quote
Old 02-06-2012, 07:42 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
There are only two ways to attach carpet to stairs and both ways will damage the treads. Staples and glue will mess your treads up, if you are worried about slipping why not get some none skid (sand like) to go in a clear finish to go on the treads, it won't be visible and you won't be slipping and it isn't that expensive.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 02-07-2012, 12:45 PM   #3
Attachment damage
What about peel and stick, or double sided tape? Will those ruin my treads? They are getting scratched up from my dogs nails so carpet will not only make it safer, but it will also stopp the damage. No?
Old 02-07-2012, 01:26 PM   #4
"Floor"ist
OtherFloorGuy's Avatar
We've tried the friction tape, it leaves a residue. Most adhesives can actually chemically bond with a lot of finishes.
You could try a wire scraped wood floor for the treads, but that wouldn't be cheap to install.
I'd say a carpet runner and take the plunge to put down tack strips.
OtherFloorGuy is offline   Reply With Quote
The Following User Says Thank You to OtherFloorGuy For This Useful Post:
BigJim (02-07-2012)
Hardwood or Carpet on Stairs? RugbyLove Flooring 3 11-16-2011 04:19 PM
Replacing Carpet on Stairs with Hardwood Treads Funnyflip Flooring 2 10-24-2011 08:57 AM
Carpet upstairs with hardwood stairs ... what to do with top stair? jmai14 Flooring 3 09-10-2011 09:57 PM
Need to carpet hardwood stairs clasek Flooring 7 04-21-2009 12:00 PM
Change from carpet to hardwood stairs would make it safer? KUIPORNG Flooring 4 03-25-2009 08:56 PM
