-   -   hot water pipe burst *pics* (http://www.diychatroom.com/f5/hot-water-pipe-burst-pics-17935/)
verena 03-03-2008 01:42 AM
Hi everyone
I am looking for advice. A week ago our hot water pipe under the kitchen sink burst. We live in a small condo and it flooded the kitchen, living room, part of the bedroom and bathroom. There was so much water it flooded the suite below us and cascaded like a waterfall in the parkade. We called a restoration company and they put a dehumidifier and fans and put the heat as high as it would go for 3 days. Then the dehumidifier and fans for another 7 days. The carpet was soaked and they didnt pull it? It seems dry now but how would I know if the underlay is dry? The carpet has bad stains now and they say they will shampoo it and it will come out, but they have nothing to say about the underlay. What is the right proceedure in this case? Should I get another company to come and give us there opinion?
thanks
kitchen/living room with hot water
http://i157.photobucket.com/albums/t...g?t=1204526432
Bedroom and kitchen wet
http://i157.photobucket.com/albums/t...g?t=1204526134
carpet "dry" with stains
http://i157.photobucket.com/albums/t...g?t=1204526030
JackOfAllTrades 03-03-2008 03:59 AM
How/what made it burst???
:eek:
The carpet is GARBAGE as is the underlayment. Both need to be removed, the sub floor needs to be checked for damage, and replaced if needed. OSB if wet, falls apart and loses it structural support. Plywood is better but still might need to be replaced.
At a MINIMUM, both the carpet and carpet underlayment need to be thrown out and replaced. The sub floor needs to be inspected.
JazMan 03-03-2008 12:15 PM
Verena,
Is your insurance company involved in this? You said "YOU" called the restoration company. I imagine you called yourself to get things going so not to waste too much time?
Jaz
verena 03-03-2008 03:08 PM
yes we called the restoration company to save time. There was water everywhere. Our insurance doesnt do anything in this case as all damaged items are original to the building they go under strata insurance. This is where the fustration is because strata is the "customer" not me, thus my views are nothing to them.
I figured the carpet has to go but they insist its fine? It just doenst make sense to me!!
verena 03-03-2008 03:10 PM
And I just found out today from the plumber who was here that the water pressure in the building is too high and probably has a shot pressure reducing valve. This is why my pipe burst.
:eek:
redline 03-03-2008 05:07 PM
:eek:
How many condo's in this building?
is the underlayment wood or concrete?
verena 03-03-2008 07:08 PM
I think 56 units. The building is a wood structure, except obviously the ground floor which has a parkade below it.
redline 03-04-2008 09:41 AM
Who is responsible for maintaining the water as it enters the building? (hoa)
Did you get a written statement from the plumber that the water pressure was high?
I would pull up a section of the carpet were there was water and see the condition of the wood floor.
