Hollow Sound After Cement Dried - Flooring - DIY Chatroom Home Improvement Forum
Old 08-20-2008, 10:30 AM   #1
hollow sound after cement dried
Hi - My husband and I just installed ceramic tiles using mortar last night. This morning I was cleaning up and preparing for the grout finish. I went around knocking on the tiles. Most are solid as a rock but a few have a hollow sound in the corner. Is this normal - I have a sneaking suspicion that they will crack a month from now. If this is a horrible mistake can we correct this in any way (maybe push the grout in there more aggresively?) Do I have to remove them?
Any help would be appreciated before we continue with the job.
Thanks,
jeannieB
jeannieB is offline   Reply With Quote
Old 08-20-2008, 04:44 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What type of adhesive did you use?
If the adhesive has had ample time to dry and you are getting a hollow report when you tap on the tiles - then, the tiles are not bonded to the substrate. They should be removed and reinstalled.
Old 08-21-2008, 08:15 AM   #3
RippySkippy's Avatar
I'd remove the questionable tiles...look at the bright side...it'll be easier now than after it's grouted. What size tiles?
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Soundproof Windows BlueJello General DIY Discussions 3 11-30-2007 05:34 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 02:25 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 10:22 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
