Holes/craters In Concrete Slab - Flooring - DIY Chatroom Home Improvement Forum
Old 04-27-2012, 08:17 PM   #1
Question
holes/craters in concrete slab
I recently had carpet removed from my cement slab. Tack strips were nailed to the slab. When they were removed, there are now holes/craters. I'm going to install a floating floor.
What is the best preparation to repair the holes/craters before I lay the planks?
diyers is offline   Reply With Quote
Old 04-27-2012, 10:14 PM   #2
Rewards Points: 14,300
Why do you need to fill them?
A floating floor could care less about a few holes.
What type floating floor do you plan on installing?
There a whole process if you plan on installing laminite, and some are not rated for below grade so keep that in mind when picing one.
Has there been a moisture test done?
concrete porch slab questions Queso Bandit Building & Construction 2 06-29-2011 10:31 AM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 02:45 PM
Help stone over concrete slab Johnnyquest Flooring 0 05-20-2011 03:36 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 12:23 PM
PVC underneath the floor (concrete slab) massimo Building & Construction 6 11-19-2008 10:37 AM
