#1 |
hole in floor?
Hi I'm not sure this is in the right category but in my basement floor there was a hole drilled in it about the size of a pencil. It is no where near the laundry room sump pump or shower, just close to an outside wall on the other side of the room. Any idea why it's there or is it ok to fill it in?
Thanks for the help! |
#2 |
hole in floor?
Maybe something used to be screwed to the floor there, and the hole is where the screw used to be. Could have been anything. Can't imagine why you couldn't fill it in.
| The Following User Says Thank You to RDS For This Useful Post: | lappson28 (01-27-2011) |
#3 |
hole in floor?
Go ahead and fill it in.
1. Someone was drilling something set on the floor and marred the floor because the drill went too far. 2. The hole was meant to hold a stud that in turn kept a piece of furniture or an appliance in place. 3. The hole was used to drain a very small or very slow water flow such as from a dehumdifier (assuming the hole goes all the way through the floor slab). 4. The hole was left over from a spacer bar or a stray nail in the forms used when the slab was poured.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded. Last edited by AllanJ; 01-21-2011 at 01:51 PM. |
| The Following User Says Thank You to AllanJ For This Useful Post: | lappson28 (01-27-2011) |
| Display Modes | |
| How to anchor toilet flange to porcelain tile? | bobmg | Plumbing | 29 | 03-30-2012 12:09 PM |
| max hole in 2x8 floor joist | nfslane | Building & Construction | 4 | 06-24-2010 05:53 PM |
| How to frame new floor to match existing floor height | taylor01 | Carpentry | 4 | 04-04-2010 09:59 PM |
| How to cover a hole in a floor slab | tomseeley | Flooring | 2 | 11-16-2009 01:14 PM |
| My Hardwood Floor Refinishing project | roxksears | General Discussion | 3 | 11-13-2009 06:43 PM |
