Old 10-05-2007, 07:00 PM   #1
Question
Hole in the concrete slab
Hello all. We just relocated our laundry room and are left with an area about 4'X3' by 2" deep where the washer and dryer sat. There is a french drain in the bottom of the "trench". This space will be a walk-in pantry with wire shelving sitting on top of whatever we decide to fill the hole with. We are not wild about the idea of carrying or wheel-barrowing that much concrete across the good floors. For the short term, we were considering filling the void with 1'X1' concrete pavers, since the size is fairly predictable, and maybe putting a little morter in the spaces. Anyone else have any ideas?
shapeshifter is offline   Reply With Quote
Old 10-06-2007, 09:37 AM   #2
You may consider mixing the concrete in the hole. Get it as close to the surface as possible and finish with a good portland patch.
flooring dude is offline   Reply With Quote
Old 10-06-2007, 12:22 PM   #3
Hey, that's something we hadn't considered. We could tape off the surrounding floor, which also happens to be concrete.
We should just be able to mix the stuff with a hoe and level with a 2X4, I would think.
Should we try to do a little bit at a time so we don't over fill?
Old 10-06-2007, 01:46 PM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
They make a bag now that you mix the bag of cement in, and then carry. Otherwise, mix in a wheelbarrel, and put in 5 gal buckets to carry to the room.
Old 10-09-2007, 08:45 PM   #5
I would mix and add as necessary to reach the top surface. Don't allow to dry in layers or it won't bond to each other.
Old 10-15-2007, 07:45 PM   #6
Question
Okay, we filled in the cavity last night. We used 3 bags of 'sackcrete' and the result is pretty good. There are a couple of rough spots in the back corner where we really couldn't reach but all in all, considering neither of us has done any work with concrete, it's pretty good.
Flooring Dude mentioned a "portland patch". Could someone elaborate on that please? Where to obtain it, how to use it, etc?
As always thanks to all who respond.
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
Remodel over sloped concrete slab PSL_Hokie Building & Construction 11 07-11-2007 06:14 PM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 01:32 AM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
