Old 10-24-2012, 01:20 PM   #1
HHI carpenter
How do I remove outdoor carpet glued down to a concrete front porch.
carpenter6man is offline   Reply With Quote
Old 10-24-2012, 05:25 PM   #2
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
HHI carpenter
Floor Scraper and some curse words. If put down properly with bonding adhesive, it is not going to be EZ. You can then remvoe the adhesive with a power washer, which will be a very time consuming proposition, but will work with tenacity.
There may be a better solution, but I don't know of any.
-Grumpy
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 10-24-2012, 06:09 PM   #3
HHI carpenter
I'd prefure being poked in the eye with a stick then to have to scrape off another glued down carpet. But you have to do what you have to do.
What's the plans on what to put down once it's gone?
Northern Tools sell a pneumatic floor scraper. Sure would save getting all those blisters. Works the same as a hand scraper but the blade moves back and forth doing all the work, not the handle like a hand scraper.
Old 10-24-2012, 06:29 PM   #4
An old Tradesmen
HHI carpenter
Moved to Flooring forum.
Carpenter Ant Elimination SheeB Pest Control 1 08-15-2010 06:50 PM
hahaha! I think I found the main carpenter ant nest! How to destroy? diy'er on LI Pest Control 5 05-29-2010 01:40 PM
