-   -   Help on tool selection for leveling concrete slab (http://www.diychatroom.com/f5/help-tool-selection-leveling-concrete-slab-75877/)
Wohn 07-10-2010 10:06 PM
Hi, I am redoing my bathroom and the the concrete slab is very uneven, about 3/4" higher in a 2x2ft section of the floor.
The room is small about 5x6'. I need to remove the extra height in the one corner to level out the floor so it can be tiled. The previous owners put in 1x1" tiles so they wouldnt have to deal with it. I plan on using SLC after to fill in minor dips and cracks but I dont want to put a 1" coat of SLC on top because then it will raise the whole floor above the hallway floor and I will have to redo the toilet flange thats embedded in concrete.
What tool can I use to remove the excess concrete in that area. The concrete is about 30 years old give or take 3 years. Will a concrete surfacing grinder take that much out? Is there a better tool to remove it? Maybe an angle grinder with a diamond wheel?
John
jlhaslip 07-10-2010 10:19 PM
a concrete cup stone on a grinder might be a good start, but they are messy/dusty.
Wohn 07-10-2010 10:27 PM
Thanks,
As it is im coughing up blue chunks from the blue grout from the tile removal. :thumbup:
I see they have ones with a shopvac attachment to contain the dust. I assume that they would remove about 1/8" - 1/4" a pass? Im planning on renting since Im not going to justify 350-400 for a small job.
tacomahardwood. 07-11-2010 02:03 AM
Home depot has a grinder with a concrete cutting wheel , and a vacume hook up , I have used it , It seems the difficulty would be in a corner ,since it is a round wheel .... tacomahardwoodfloors.com
