Help Tile Underlayment - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-20-2014, 09:59 PM   #16
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Originally Posted by jayd33- View Post
The nightmare of this job is the funny part lol one thing after another.
Well after looking around i found that i can pull it off but the dishwasher is going to be like a 1/4" below the granite countertop is this going to be a problem other than screwing the dishwasher top to the bottom of the granite.
Seeeeeeeeeeeee! What'd I tell ya?
The dishwasher also has adjustable legs/feet on the front that may still have some adjustment in them.
Old 05-20-2014, 10:08 PM   #17
Just measeured not going to fit i thought the coutertop bottom was 36" but its 35 lol i think i have no choicse but to lift everthing some how lol
jayd33- is offline   Reply With Quote
Old 05-20-2014, 10:11 PM   #18
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Okay-a...so what about the front legs on the DW?
Old 05-20-2014, 10:17 PM   #19
Haha all the way down its just to high well i guess the kitchen is coming out wish me luck not to crack any of the granite lol thanks for your help though
Old 05-20-2014, 10:22 PM   #20
Tileguy
JazMan's Avatar
Rewards Points: 424
Cabinets are 34.5" tall, this means they're shimmed 1/2" over the subfloor. Or is there that 1/4" ply under the cabinets too? (shouldn't be, but check).
You can adjust those feet of the dishwasher. Heck you can remove them altogether. I have found you usually need about 34 3/8" for the washer, but they're not at the same. The tallest part is the front, often you can tilt it in. You don't need to tile under the DW, end it so the grill sits on the tiles. You can do a mockup away from the counter using a board to simulate the granite. Years ago there were machine that were not as tall, I think Bosch had some that were around 33". Not sure about now a days.
You don't haveta screw into the granite to stabilize the DW. You can screw the sides into the cabinets. That's what I did using 2 stainless screws with grommets.
Jaz
Old 05-20-2014, 10:31 PM   #21
Tileguy
Bud Cline's Avatar
Rewards Points: 558
HOLD ON FOR GADS SAKE !!!!
This would be less painful if you would slow down and listen and stop trying to jump ahead.
In more than thirty-five years of doing this stuff I have never-once had a dishwasher that couldn't be made to work.
You had better be emotionally and financially prepared to replace your granite counter tops if you try to move them and things don't go well for you. Something tells me things won't go well for you.
Hey by-the-way...
Are you personally intending to perform this work yourself or are you just investigating before you hire it done for you by someone else?
Old 05-20-2014, 10:40 PM   #22
Ya he rebuilt the kitchen with 1/4" plywood its under all the cabinets im trying to figure away to shim it up and try get another 1/2" board under the cabinets there has to be an easy way lol
Old 05-20-2014, 10:43 PM   #23
myself cant afford to hire someone. but thought i better look into this before continuing what he was going for now i know why he gave it back to the bank lol.
I want to do it right with least of headaches
Old 05-20-2014, 10:56 PM   #24
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why not remove what you can get to and leave the rest alone? You are making this way more difficult than it needs to be.
Vinyl Tile over rough wood underlayment cindinw Flooring 4 07-25-2011 06:36 PM
ceramic tile, underlayment questions jpc Tiling, ceramics, marble 3 12-14-2010 11:47 PM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 07:06 PM
Best option for underlayment under a tile floor. Weathermaker01 Flooring 8 06-20-2008 10:08 AM
Tile Underlayment billinak Flooring 5 09-29-2006 05:21 AM
