#1 |
Help with Tile Installation for First-Timer
Hello!
We are attempting our first tile installation in the kitchen. We have tore out 3 layers of lino and luwan (spelling?) and got down to OSB board. The tile guy we hired says that the morter will not stick to the OSB board, so just nailed down 1/4" hardi-backer board on top of OSB. Floor is almost all the way level, but about 1/2" slope over an area of approx. 5 feet to one corner of kitchen... We did use tape on seams and morter, and now we are ready to lay tile... is there anything I can do to correct this slope? Is that amt. of slope really that terrible? I have a feeling we should have leveled it out using morter BEFORE we put down the cement board? I can't rip it out now... it was nailed down with hundreds of ring shank nails.... Just some friendly advice from an expert would put me at ease.... House was built in 1898, and floor leveling is not terrible for this old of a house, I believe.... Thanks in advance for your advice!!!!
#2 |
Tileguy
You could not have levelled the floor with mortar and then installed the cement board, it doesn't work like that. So without knowing it, you are on the right track so far.
Tile doesn't care if your floor slopes but the problem may be (depending on the size of tile used) [the problem may be] when the tile crosses over the beginning of the slope there will be some serious lippage in the tile edges. Meaning tile edges will be higher than adjacent tiles, be ugly and create a tripper maybe. The professional-fix would be to pour some Self Levelling Compound (SLC) into the low area and feather the edges of the compound onto the existing more suitable surface. Regular mortar will not do this, it will take SLC.
#3 |
Thanks Bud! Boy, you are very helpful on here -- I've already read through many of your replies... ok, so I will get some SLC, and this can be laid along with the morter before we lay tile? The tiles we have are rectangular shape, like 8 x 3 I think... ??? Is it a big deal we did not use morter under the back board? Also -- big deal we used ring shank nails instead of screws?
Thanks again for your help!!! |
#4 | |||
Tileguy
Help with Tile Installation for First-TimerQuote:
| The Following User Says Thank You to Bud Cline For This Useful Post: | bethinmi (10-27-2011) |
#5 |
Ok... thanks for response, maybe i will start ripping out the hardibacker tonight to re-do it with morter underneath...
then hardi-back board, then self-leveling morter, then regular morter than tile, grout, etc. thanks for your help. and we did use galvanized roofing nails, i think? but i think we will go for using the screws after we rip it out! thanks again for your help! |
#6 |
Tileguy
Screws aren't totally necessary. Roofing nails work as well and aren't as much hassle. If you do opt for using screws use the proper cement board screws and BE SURE you use the ones with the square drive. Cement board screws will have the proper alkali resistant coating, they will have double thread one high one low, and they also have little nibs under the head so that they are self-setting. Typically unmodified thinset is used under cement boards. Install/apply the thinset with a 1/4" X 1/4" X 1/4" notched trowel.
| Display Modes | |
| Porcelain Tile installation | Fields31 | Tiling, ceramics, marble | 8 | 10-08-2011 11:25 PM |
| glass tile installation | julrich7 | Tiling, ceramics, marble | 2 | 09-12-2011 06:14 AM |
| Help! Armstrong "luxury" vinyl tile installation | BlueBSH | Flooring | 2 | 02-17-2011 09:27 AM |
| granite tile countertop installation | had | Building & Construction | 3 | 04-01-2009 06:30 AM |
| Ceramic Tile Backsplash Installation | DK75 | General Discussion | 4 | 11-01-2006 08:56 PM |
