Help, Sturd-i-floor Plywood Got Rained On - Flooring - DIY Chatroom Home Improvement Forum
Old 03-22-2012, 04:58 PM   #1
Help, Sturd-i-floor plywood got rained on
I just bought 14 sheets of 3/4 Sturd-i-floor t&g plywood. As we were unloading, the sky opened up and rain poured down for about 10 minutes and then stopped. About 3 sheets got soaked before I decided to leave it stacked in the pickup hoping that the top sheet would protect the other sheets.
My question is: do you think the sheets that got soaked are ruined? The other sheets got wet at the toung and grooves. Do you think they are ruined? I wish I would have spent a few more dollars for the dryply.
Don't know if it matters but I will be removing old 1x subfloor and using 2 layers of the sturdi floor and ditra as underlayment.
Thanks in advance for any advice.
diynoob1 is offline   Reply With Quote
Old 03-22-2012, 05:15 PM   #2
Rewards Points: 13,994
Should be fine.
http://www.gp.com/build/product.aspx?pid=1396
And your right Advantech would have been a far better product.
Old 03-23-2012, 12:37 PM   #3
So if the edges swell, I will have to sand them down, correct? What tool is best for this, a belt sander with coarse grit paper? I have a random orbital sander but i dont think that would do the job, correct?
New Concrete slab has been rained on ... crud ... kronic24601 Building & Construction 7 11-07-2011 09:39 AM
it rained after applying flood oil stain on my deck john 3:16 Painting 0 07-13-2011 03:47 PM
rained on tiles? whit13 Tiling, ceramics, marble 5 04-13-2011 07:48 AM
How long do I need to wait to shingle if my felt has been rained on? J S Machine Roofing/Siding 3 03-19-2011 11:17 PM
