Old 10-22-2009, 02:49 PM   #1
Default Help with staining my stairs
I am in the process of staining my stairs. The stairs were terribly damaged and were even moreso damaged when I applied Peel Away to get the paint off and the product turned into cement. Because of that, corners of my stairs were fried in the edges and so the edges are much much darker. I used this product on my stringers also, but after I neutralized with vinager and cleaned them they seemed okay.
A good amount of time has passed (I have house guests that wont leave the house) and I continued to sand the stairs, using fine sandpaper last. I used minwax pre conditioner, waited about a half hour and then applied Minwax oil based stain in red oak to both the stairs and stringers and wiped off any excess about ten minutes later. On the minwax can it says not to sand in between coats, so I waited over the 4 hours required to put another coat on.
My first problem is that about 75% of the stringers have a white sheen, well theres no sheen but when light hits its definitely cloudy looking. It looks pretty horrible.
The second coat of stain on the stairs is drying tacky. My feeling is that I should wait until they finally dry and use some steel on the stairs and start the second coat again-but again, the Minwax can advises against that.
My last question is how many coats of stain is too much and can you use a darker color over a lighter color? I know I cannot blend the stairs discoloration great, but I would like to try to even it out a little better than what the red oak is achieving.
kimber is offline   Reply With Quote
More On This Topic
If we were doing something like say touch up, like this for instance. Like this was a broken piece and the arms were broken off, this was broken off and the leg was broken off here. The moving company had damaged it, so the people brought it to us to... Read More »
Okay now we've gone all the way around the state here and ironed on our edge banding and trimmed it off, so the last step is going to be to put a little bit of color on this edge banding if you want to. This is optional. I'm going to use some very light... Read More »
Sure, it feels great on your skin, and you can cook with it but what else can you do with coconut oil? Read More »
Hello! My name is Grady Johnson and I'm a professional painter, and today I represent expertvillage.com. Now we're going to talk a little bit about the materials we're going to need to paint the exterior eaves on our house. Now, whenever you're painting... Read More »
Hello! My name is Grady Johnson and I'm a professional painter, and today I represent expertvillage.com. Now we're going to talk a little bit about painting the exterior eaves on the house with an acrylic latex semi-gloss enamel. Once everything is... Read More »
Painted the stairs ... . kimber Painting 8 10-07-2009 01:50 PM
Outdoor stairs need to be fixed... 2031pratt Carpentry 2 08-06-2009 01:06 AM
Questions about building stairs. cvriv.charles Building & Construction 5 07-05-2009 04:50 PM
Removing wall under stairs Lankston Building & Construction 3 06-10-2008 09:50 AM
open stairs = header jamesdart Building & Construction 0 09-08-2006 04:33 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
