Help! Shellac Color Too Dark On Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 08-14-2010, 08:55 PM   #1
Post
Help! Shellac color too dark on floors
I have some old antique heart pine floors that we have spent many many hours prepping, sanding and filling (there are a lot of gaps from wear). Well, today we moved forward and put on the first coat of amber shellac, and....I'm afraid I made the wrong decision with the color. The formerly very light pine color has changed to a fairly deep orange, but the filler has stayed pretty much yellow/white, so now there is a HUGE contrast between the floor boards and the filler. So basically the darkness of the stain has really highlighted all of the gaps, missing chunks, and other damage to the floors and made them look WORSE than before we applied it. Rather than making them look new it made them look dilapidated.
Is there ANYTHING I can do to make the floors lighter, besides totally resanding to strip the shellac off? Can we do a light sand tomorrow and then apply a clear stain on top? After all the many hours and hours we've put into these floors, I'm freaking out a bit about what I feel was a bad decision....Any help would be much appreciated!
atreyu312 is offline   Reply With Quote
Old 08-15-2010, 12:49 AM   #2
jlhaslip's Avatar
Rewards Points: 2,196
wash/wipe the shellac with denatured alcohol. the dna will thin the shellac and wiping it will remove if from the floor onto your cloth. change your rag often. do a small test spot first.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 08-15-2010, 11:06 AM   #3
Ok thank you!
Old 08-15-2010, 06:28 PM   #4
Rewards Points: 1,596
Make sure you've no open flames or sources of ignition (hot water heater pilots) that could light off the alcohol vapors; ventilate the space well with open windows/doors.
bob22 is offline   Reply With Quote
Tags
floors , shellac , stain
Laminate Floors Too Dark! ledlover2 Flooring 6 07-12-2014 09:43 AM
Resurfacing Wood floors roxksears Building & Construction 2 10-23-2009 08:50 AM
I Hate Ice Stubbie Off Topic 20 12-21-2008 11:41 AM
Do dark wood floors make a room feel smaller? drh Interior Decorating 6 10-30-2008 08:48 PM
Dark stained oak floors Dave Theyn Flooring 2 10-14-2008 07:08 AM
