Help For Removing Mastic From Aspestos Tiles - Flooring - DIY Chatroom Home Improvement Forum
Old 06-15-2009, 09:34 PM   #1
help for removing mastic from aspestos tiles
We have old carpet tiles that are being held down by a black carpet glue (that is not working well as the carpet tiles are coming up.) The black mastic is thick, almost like foam. It too has started to come up. (we are in the process of getting the black mastic checked for asbestos and we should have the results by tomorrow) We need to remove the mastic, (as my two year old has started to eat pieces of it) but underneath is asbestos tiles. Assuming the mastic has no asbestos, how do we remover the mastic without disturbing the tile underneath as we cant just scrape it (because it could damage the tile below.) Thanks to anyone with suggestions
shellystar is offline   Reply With Quote
Old 06-16-2009, 02:04 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
Do you know for certain that the tiles are asbestos? You should have sent a sample of the tiles and the mastic holding them down to be tested as well. Not all tiles are asbestos. Even 9x9s were made without the big A.
Asbestos tile and mastic phillyDIYER Flooring 14 08-21-2011 01:46 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Tiles cracking, popping, grout falling out. Mojomama Flooring 8 03-19-2009 08:50 AM
calking backer board to tub glassman General DIY Discussions 13 06-19-2008 08:41 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 07:43 PM
