Help, Removed Carpet Running And Stain Is Uneven! - Flooring - DIY Chatroom Home Improvement Forum
Old 05-29-2012, 06:40 PM   #1
Help, removed carpet running and stain is uneven!
Previously my stained pine oak stairs were covered by carpet runner and only the edges showed. I removed the carpet and although the stairs we're stained at the same time, there is a significant difference between the edges and the previously under carpet part.
I'm not sure what to do here. It almost appears the edges were stained again after the runner was laid. I'm afraid only spot staining the middle will lead to more uneven stain issues. (Attached a picture)
Please help!
Pic of stair stain
http://flic.kr/p/c7VNxQ
Jocrazy is offline   Reply With Quote
Old 05-29-2012, 07:59 PM   #2
Seems to me, you have three choices...
1. Re-stain the treads and try to match it.
2. Strip and re-stain the entire stair case.
3. Put down another runner.
oldhouseguy is offline   Reply With Quote
Old 05-29-2012, 08:19 PM   #3
Stairguy
Millertyme's Avatar
Rewards Points: 508
The uncovered portions have started to darken over time, as most wood will, regardless of the stain. yes you could try to match the middle part to the edges but this may be difficult, not to mention almost impossible to blend the 2 together without seeing some type of overlap or seam. Best bet woulkd be to sand down to bare wood and start fresh. Just stripping will probably not due. It will need to be sanded to get the part that was exposed to daylight to match the part that was covered. I think the mismatch color is in the grain of the wood not the stain.
Millertyme is offline   Reply With Quote
Old 05-29-2012, 08:24 PM   #4
Rewards Points: 340
I would try some fine steel wool first - it may only be the finish that has faded. If not satisfied, then use one of the other options.
tribe_fan is offline   Reply With Quote
