Help With Peel And Stick Vinyl Planks - Flooring - DIY Chatroom Home Improvement Forum
Old 05-12-2010, 08:33 PM   #1
Help with peel and stick vinyl planks
I am needing some suggestions... here is the situation. The room I want to install peel and stick vinyl planks in has 3/4" OSB subflooring, and the room is in between two other rooms. The manufacture of the flooring stated not to install the planks over OSB and I can not go and higher than 1/8" of additional material over the OSB because the flooring of the other rooms will not match up. I have tried all the surrounding lumber, hardware, diy chain store, etc. looking for 1/8" luan plywood but none of them carry it 1/4" is the thinnest they have. I have wondered if some type of floor sealer or something along that lines would work. Am open to any other material or products you can think of. Any help is greatly appreciated.
Rich
Rich_B. is offline   Reply With Quote
Old 05-28-2010, 12:30 PM   #2
Tool Cop
Rich
Would this rubber underlayment work for you? http://www.greatmats.com/products/ru...derlayment.php It comes in 1/8" thick, so it sounds like it could be a winner.
TrafficCopSmith is offline   Reply With Quote
Do I fill the cracks when I am putting peel and stick tiles? bherdman Flooring 5 04-05-2010 04:01 PM
Re-Roofing: Okay to Re-Use Peel n Stick? GrillMouster Roofing/Siding 8 12-06-2009 01:55 PM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 06:08 PM
Peel and stick matching melkisadek Flooring 6 01-16-2008 07:52 AM
Installing 'peal and stick' vinyl squares on top of existing .... alexz Flooring 8 02-17-2007 04:20 PM
