HELP NEEDED!!! - How To Remove Glue From A Concrete Slab - Flooring - DIY Chatroom Home Improvement Forum
Old 06-23-2012, 08:15 PM   #1
HELP NEEDED!!! - How to Remove Glue from a Concrete Slab
I have engineered wood on my floor and would like to remove the wood and glue so that the floor can be properly leveled, etc. and the floor replaced with hardwood flooring. I was told the glue could be heated and removed but based on some information I have seen posted on this site that is not a good choice. Today I was told that mineral spirits could be used. Any thoughts as to the best method and/or whether the mineral spirits wold work.
tclenn is offline   Reply With Quote
Old 06-23-2012, 10:46 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 82
Mineral spirits may keep any future adhesive from bonding. The best way to remove it is scraping or grinding.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
tclenn (06-25-2012)
Old 06-23-2012, 11:00 PM   #3
Agreed. Scrape it.
CopperClad is offline   Reply With Quote
The Following User Says Thank You to CopperClad For This Useful Post:
tclenn (06-25-2012)
Old 06-24-2012, 06:26 AM   #4
If its a small area razor scraper, if you can handle equipment rent a power scraper if not there are companies that remove it professionally
allfloorremoval is offline   Reply With Quote
Old 06-24-2012, 10:04 AM   #5
So you are pulling up engineered? How are you putting the 3/4 solid down? To get up old glue 4" razor scraper is the best way. Change the blade often. Good luck. Do not glue down the solid wood with out screeds and tar as a moisture barrier. Could you sand and finish the engineered?
Thefloorman is offline   Reply With Quote
Old 06-25-2012, 06:08 PM   #6
I was in the tool rental area in Home Depot yesterday but they said they do not have any equipment for that task. Any idea(s) on another place to check?
Old 06-25-2012, 06:11 PM   #7
There isn't anything wrong with the engineered wood however in certain areas where the wood was put down it pops when it is walked on and although this contractor was recommended to me I don't think they did a good job. So now I am considering trying to replace a section of floor at a time and with a lighter color wood than before.
Old 06-25-2012, 06:13 PM   #8
According to the Home Depot I visited yesterday they do not have such a piece of equipment for rent. Do you have any names of reputable companies that do such work.
Old 06-26-2012, 07:41 PM   #9
Where are you located?
Old 06-28-2012, 09:21 PM   #10
New Jersey
Old 06-29-2012, 06:22 AM   #11
feel free to PM or email me I will try to help you out
Lay plastic between ground and concrete slab? Flt_Simulation Flooring 8 04-22-2012 05:56 AM
Removing basement tile and pouring concrete slab tondar Building & Construction 12 11-05-2010 11:28 AM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 03:56 PM
20x20 Porcelain Tile over Linoleum on Concrete Slab scbauer Tiling, ceramics, marble 3 08-31-2010 07:11 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
