Help Needed With Floor Joist Cut For Toilet Plumbing - Flooring - DIY Chatroom Home Improvement Forum
Old 02-14-2011, 09:44 AM   #1
Help needed with floor joist cut for toilet plumbing
Hello,
I am new to this forum and hope someone can help. During a bathroom remodel we discovered that someone had cut all the way through a floor joist and run the plumbing pipe up through the subfloor. Why I do not know as now the on either side of the pipe is basically hanging in the air, no support. What is the best fix for this? Hanging a whole new 16' long 2x10 joist is not going to work, too many other pipes, hvac, electrical in the way. Would making a sandwich of the joist work - using spacers to bring the width of the joist beyond the 3" drainage pipe on both sides of the cut joist and then using the longest joist we can as a sister joist on either side?
lb3gunny is offline   Reply With Quote
Old 02-26-2011, 08:47 AM   #2
Pro Newbie, Thank You!
Lets see...
Joist 'A' =======================
Joist 'B'/Pipe ======== @ =========
Joist 'C' =======================
That right? If so, nail or screw a 2x10 scab on either side of the pipe to the good joists (A & C) and have the cut joist (B) butt into those, nailed or screwed of course. Looks something like this:
Joist 'A' =========================
scab................... !!.... !!
Joist 'B'/pipe =====!! @ !!=======
Joist 'C' =========================
I will try to find an actual photo of this in my collection. Let me know if you don't quite follow. And don't mind all those periods in the second 'drawing'.
Broadhurst is offline   Reply With Quote
Bathroom remodel, sink plumbing dschmid Plumbing 3 02-03-2011 08:32 PM
Basement Bathroom - plumbing thoughts (pics) rkerns Plumbing 1 01-12-2011 04:14 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
new plumbing in kitchen What have I done Plumbing 1 07-29-2006 11:14 AM
New home plumbing cost wdsfr1968 Plumbing 7 07-28-2006 09:41 AM
