Help Needed With Buckling Hardwood Floors! - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-26-2010, 09:15 PM   #16
floor_whore
Send a message via Yahoo to Aaroncarpet
Glue down Slab
you have to go after the installer.....the woood wasn't conditioned and a moisture test wasn't validated...... the installer put the floor together too tight and because it is a glue down, it can't be repaired....it must be replaced....maybe you should consider an engineered floor like bruce...but do a thurough moisture test to see if the conditions are acceptable and let the new material sit inn your basement opened up and condition it for 30 days...
Aaroncarpet is offline   Reply With Quote
Tags
buckling , hardwood , moisture
New buckled hardwood floors Angela3511 Flooring 12 07-16-2009 08:58 PM
Help Needed - Hardwood Floors ryben6 Flooring 3 03-25-2009 11:54 AM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
Hardwood Floors Help Needed - I'm off by 3/4" balmer_hophead Flooring 10 07-09-2008 09:22 PM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 08:06 AM
