Help! Need To Saw Next To Cabinets - Flooring - DIY Chatroom Home Improvement Forum
Old 05-07-2007, 08:38 PM   #1
Help! Need to saw next to cabinets
I need to cut through the kitchen laminate and 1/2" plywood. Prep for hardwood flooring W/O removing the cabinets. I need a saw that can cut very close to the cabinet edge and ALSO I need to saw the areas that are under the overhang where your toes/feet are. A low clearance saw, whats out there that works. Rental options?
thanks.
shotdown is offline   Reply With Quote
Old 05-07-2007, 09:33 PM   #2
Master Craftsman
Big Dave's Avatar
This is what you need. Not sure if a rental store would have it though.
http://www.carpettool.net/toe_kick_saw.asp
Do one thing at a time, do it well, then move on.
www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
Old 05-07-2007, 10:07 PM   #3
Or, check into the Fein Multimaster. It's probably a bit more expensive, but a handy tool
send_it_all is offline   Reply With Quote
Old 05-08-2007, 08:17 AM   #4
not a total Newbie
Some creative Sawzall / reciprocating saw work might do what ya need...especially if you're going have baseboards that might hide a less-than-perfect cut.
space_coyote is offline   Reply With Quote
Old 05-08-2007, 08:33 AM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
It's next on the toy list. Did you buy yours locally or order it?
- Build Well -
Old 05-08-2007, 08:36 AM   #6
thanks.
An ''Undercut Saw''....standard tool used by all flooring installers.
Should be available to rent.
Example Link:
http://www.tools4flooring.com/crain-...93af92be3a5adf
- Build Well -
Old 05-08-2007, 09:03 AM   #7
Master Craftsman
Big Dave's Avatar
Example Link:
I think you misunderstood the question. He needs a toe kick saw like what I linked to.
Old 05-08-2007, 09:18 AM   #8
NO DAVE, My answer is better...........
(Yes....I very well could have misunderstood the question)
- Build Well -
Old 05-08-2007, 09:19 AM   #9
Master Craftsman
Big Dave's Avatar
It happens to the best of us.
Old 05-08-2007, 09:27 AM   #10
Thanks I new the perfect tool would be out there. A Toe-Kick saw. Would you hire an installer with 20 years hardwood flooring experience and no toe-kick saw? What's wrong with this picture? Sounds like a 20 year housekeeper with no vacuum!
Old 05-08-2007, 09:44 AM   #11
Master Craftsman
Big Dave's Avatar
A toe kick saw is one of those once in a lifetime tools. Some installers wouldn't even mess with such a job. Ask for credentials not what tools he has.
Old 05-08-2007, 12:27 PM   #12
Yeah, I agree the credintials are more important than tools. But really, "a once in a lifetime tool" ??? For who?? A DIY for sure! But a so-called Pro? If a Pro wants to pass on almost every flooring install because it does'nt include prior tear out of the cabinets than, more power to him!! Fortunately my first call to a rental shop was successful. $22 for 4 hr. or $30/all day. Still, I agree with your main point, trust but verify with credentials! Thanks.
Old 05-10-2007, 11:21 PM   #13
Well, I went and rented a Crain Toe-Kick saw. Would you believe it that the minimum clearance of that saw is 3 1/2" and of course I have 3 1/4" vertical clearance. Anyway, I made that thing work! The only thing I broke was the so-called safety guide. What a joke. Breaking that safety thing actually made the tool work better. At least for me!!
In addition, I used my sawzall, inherited by the death of my passing Auntie Joyce last year, Thank you Auntie Joyce. That came in handy too. Not to forget the two wood chisels for the areas otherwise left untouched by the two afformentioned tools. $10- word. Let me tell you, chiseling plywood is tedious but having the right tools, it's do-able!! Thanks for the tips. That 1/2 plywood, supporting the cabinets is FLUSH with the cabinet verticals. If that doesn't help the flooring installation, nothing will!
Old 05-11-2007, 12:35 AM   #14
I got mine at the JLC trade show in Anaheim, Ca. last year. I dont use it very often, but in certain situations its unbelievable.
Old 05-27-2008, 10:19 PM   #15
Merlin1964
Hi, I know it's been over a year since your post on the toe-kick saw, but I'm in need of the same tool for the same reason. I'm trying to locate somewhere I can rent one. Can you tell me where you found a toe-kick saw rental? Thanks.
merlin1964 is offline   Reply With Quote
Are they good Shenandoah Cabinets good quality? robertmazzo Carpentry 76 05-14-2015 09:23 PM
Cabinets over tile, or tile around cabinets??? harleysilo Remodeling 10 11-02-2012 01:25 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
Can Shenandoah Cabinets from HD hold weight for book cases/home Office? Leibrook Carpentry 3 12-10-2006 05:26 AM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 10:23 PM
