Help! My Toilet Has Been Leaking For About A Week - Flooring - DIY Chatroom Home Improvement Forum
Old 03-19-2010, 11:38 AM   #1
help! My toilet has been leaking for about a week
My toilet has been leaking for about a week on freshly layed tile.will the grout be ok if we change the wax ring on the toilet? The grout looks wet but not cracked.please help!
sabina is offline   Reply With Quote
Old 03-19-2010, 12:40 PM   #2
Rewards Points: 352
where is it leaking from?
Does it leak all the time or just when you flush it?
If it leaks all the time check the angle stop, supply line, and the tank to bowl bolts
If it leaks when you flush it check the tank to bowl gasket, wax ring
If the water closet was removed to tile the floor and none of these identify the problem it is possible the toilet is cracked
plumberinlaw is offline   Reply With Quote
Old 03-22-2010, 07:50 PM   #3
Handyman
Rewards Points: 512
Once you have corrected the leak, and if the grout is not cracked, you should be ok but the moisture may change the colour of the grout after it is dried. Grout is a cosmetic product..not a structural one.
canadaclub is offline   Reply With Quote
Toilet leaking at the base on floor John24689 Plumbing 4 10-19-2009 08:03 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 04:28 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
Leaking pipe under toilet aprildawn Plumbing 4 01-21-2007 04:32 PM
