Old 10-28-2009, 05:52 PM   #1
Default Help -my floor joist are drastically uneven
I just inherited a house that was built in 1859. It is an old farmhouse. 2 story. An addition was done but the upstairs floor is approx 6" higher than original floor. I really want to level this out and increase downstairs ceiling BUT am I asking for a headache? My thought was to gut house - intall new trust joists ( I think I spelled that correctly) - done. But....... I could use some opinions. Am I opening a 'can of worms' ??? Thanks
jgallup is offline   Reply With Quote
Old 10-28-2009, 09:59 PM   #2
YES.
The construction methods used in 1859 were very different than today.
Most often the out side walls were balloon framed.That means really long framing lumber ran all the way from the top of the foundation to the top of the second floor .
The wood is likely rough cut from a local hardwood.Could be oak,elm,poplar,I've even run across walnut!
There were no inspectors-often no plans--Just a sketch and the knowledge of the framer-All to often the farmer himself!
This may well be the biggest can of worms you have ever seen,or fairly straight forward.
Roll the dice. best of luck!==MIKE--
Old 10-28-2009, 10:17 PM   #3
Welcome to the forum! You can change your floor elevations to a certain extent by sistering joists, but this would only take some of the dips and gullies out of a room's span. 6" is a lot! You would have interior bearing walls to contend with as well as new footings for them if you properly consulted a Structural Engineer to get a plan of attack. As Mike said, to replace the floor system would be a total deconstruction of the roof and upper story walls, all of them.
Be safe, Gary
If you have a clothes dryer in an interior room, please check the exhaust ducting for lint build-up!
GBR in WA is offline   Reply With Quote
More On This Topic
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about buying lumber. Here I have two different types of lumber. This piece of lumber is treated and this piece of lumber is untreated. You know that it is treated because... Read More »
The rafters of a patio overhead serve two main purposes. They're meant to firmly hold the overhead in place, and they're meant to add decoration to your patio. Patio overhead rafters are moderately easy to assemble and install. Read More »
Lumber for a bookcase should be measured to the same width. Learn how to measure and cut lumber from a woodworker in this free home carpentry video. Read More »
Learn how to write "poplar tree" in Chinese radicals with mandarin characters in the free video clip. Get free foreign language lessons from an expert. Read More »
Remodeling, whether it is in the garage or in the house is a huge undertaking. One of the easiest projects is building a non-bearing interior wall. The tools are basic, as are the needed carpentry skills. The condition of the floor and ceiling will... Read More »
crowned joist / uneven floor shawn99 Flooring 12 11-04-2009 10:57 PM
Uneven ceiling dudepigeon Carpentry 3 07-08-2009 02:13 PM
Wet basement, uneven floor - what's the best flooring? pepsigirl Flooring 1 05-16-2009 09:36 PM
Installing Linoleum on Uneven Floor - and more ?'s jvoyles Flooring 0 08-13-2008 07:25 PM
fixing baseboard on uneven floors? boodog Flooring 5 10-08-2007 05:20 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
