Help Me If You Can - Flooring - DIY Chatroom Home Improvement Forum
Old 04-09-2010, 08:38 PM   #1
Cool
help me if you can
hubby and i live in a 40 yr old mobile home. there have been 4 cats and dogs live here.The carpet is stained and odor- full. We are getting new carpet. Hubby is afraid that we will start to pull up the original carpet and lots of it will stick and we won't get it all up. How likely do you think this is?
brrmrr is offline   Reply With Quote
Old 04-09-2010, 09:43 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
Depends on the kind of carpet. More than likely if it's the original carpet, the old foam pad will be stuck everywhere.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 04-10-2010, 07:30 AM   #3
Remodeling Contractor
Somewhat likely but it is easy to scrape the balance off with a simple pole floor scraper. You can buy one for about $35 or rent one.
Old 04-10-2010, 08:21 AM   #4
DIY staff
Rewards Points: 7,174
Consider painting the subfloor with and odor blocking paint before the new carpet goes in.--Mike--
Old 04-10-2010, 08:41 AM   #5
Rewards Points: 182
Wasted effort if you still have the animals. 40 year old trailer probably has particle board floors. They are most likely swelled from the urine.
Old 04-10-2010, 09:28 AM   #6
If carpet is original, odds are that it has a separate foam pad (usually very light weight) as advised in other post. Any foam that is stuck should scrape off. Hassle will be this foam pad was often stapled...and sometimes to excess. Some walls may sit on top of carpet...(this edge can be cut) ... Also as advised by others your sub floor may have issues...
lots of ways to deal with them...let us know if you find anything puzzling.
Big Bob is offline   Reply With Quote
Old 04-10-2010, 11:23 AM   #7
Rewards Points: 182
They used some huge and long staples, too.
