Help Laying Out Hardwood For Four/five Rooms - Flooring - DIY Chatroom Home Improvement Forum
Old 04-12-2013, 07:48 AM   #1
Rewards Points: 408
Help laying out hardwood for four/five rooms
All of the rooms are connected, ideally I don't do thresholds but if I do then I'd prefer it on all rooms instead of just one or two so it looks consistant. Kitchen and bathroom will be tile, all other rooms will be the same bamboo floating hardwood floor. Stairs will be hardwood too.
Which direction should I lay them and should I switch at any point (living to dining room, bedrooms, etc)?
RyanD is offline   Reply With Quote
Old 04-12-2013, 08:07 AM   #2
since your living room has the longest wall I'd go parallel with that one.
bova80 is offline   Reply With Quote
Old 04-12-2013, 08:26 AM   #3
Rewards Points: 408
Would that look odd in the hallway as there would be small strips all the way down? One of the realtors said that when we were looking at a place.
Old 04-12-2013, 08:30 AM   #4
I had to do something similar in my house and it didn't look odd.
Help laying out hardwood for four/five rooms-floor.jpg
Old 04-13-2013, 02:41 PM   #5
Rewards Points: 408
So I talked to the the guys at two stores today and they both told me that if the distance is longer than 30' I need to break the floor with a t-molding. As you can see in my above floor plan the living room down the hall is longer than 30' so would I have to put a tmolding in the hallway? That would look kind of odd and it feels like a hazard.
Old 04-14-2013, 08:49 PM   #6
Rewards Points: 99
Did the guys at the store explain why you can't go longer than 30'? I'd never heard that one before.
What kind of subfloor? Is it concrete? Plywood?
If it's the latter, you only have one choice and that is to go perpendicular to the floor joists. If it's concrete, then you can go either way.
Personally, if it's concrete, I'd go parallel with the hallway. However, if you want to get fancy, why not do an angled transition from the corner by the stairs to the corner of the kitchen/living room? Then you can have the living room be parallel with the fireplace wall and the hallway can be perpendicular to that.
Brad Nailer is offline   Reply With Quote
Old 04-14-2013, 08:55 PM   #7
Rewards Points: 81
At that point the expansion of all of the planks together could be greater than the gap that you have left at the walls causing the floor to buckle.
one cut is offline   Reply With Quote
Old 04-14-2013, 09:03 PM   #8
Rewards Points: 99
That makes sense.
But by using a T-molding, aren't you eliminating the expansion space at one end of the run? For example, if you leave 3/8" at each end, you have 3/4" available for expansion. By breaking the run with some T-molding, you've just left yourself with only the 3/8" at the one end.
Old 04-15-2013, 08:40 AM   #9
Rewards Points: 81
you have to remember to leave a gap at the molding also
Old 04-15-2013, 08:55 AM   #10
Rewards Points: 528
yes you need to leave expansion joint.
having said that, there is nothing magical about the 30' number. I would go down the hall and leave the t molding at the doors to the bedrooms.
framer52 is offline   Reply With Quote
Old 04-17-2013, 10:46 PM   #11
we are in the same situation and we have come up with the idea of laying everything at a 45 degree angle with smooth transitions between rooms, there is about 5 to 10 percent extra in waste, but the final outcome was spectacular.
urbaneve is offline   Reply With Quote
Old 04-18-2013, 12:57 AM   #12
Retired & Not Likin' It
Jim McClain's Avatar
I agree. I would not install a transition between main room and hallway.
Diagonal is one way to go, but if you are new at this, be very careful with your layout and starter course.
I do prefer to have hardwood go the length of main rooms, but this layout has a troubling hallway. Yes, bova80, it does look odd. Maybe not to you, but to most people it does. In the OP's layout, I would prefer to have the boards run the length of the hall and live with the board layout to the width in the main room. However, I have done a job or 3 where a layout similar to this had the hallway transition to diagonal boards so that the main room could have the layout longways.
Because your product requires a T-molding transition, you can lay the material in each bedroom the way that best fits your aesthetic. A floating floor doesn't necessarily have to follow the hardwood-perpendicular-to-joists rule.
Jim
Jim McClain is offline   Reply With Quote
Old 04-18-2013, 07:17 AM   #13
Jim
would have looked worse if I went the other way, the boards are perpendicular to the joists and a majority of my space is not in the hallway. But whatever works for you.
Help laying out hardwood for four/five rooms-img_4316.jpg   Help laying out hardwood for four/five rooms-img_4334.jpg
Laying solid hardwood flooring cynthiakaye Flooring 4 08-01-2012 05:25 PM
Direction of hardwood floors DBounlom Flooring 2 10-08-2011 06:37 PM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 05:15 AM
Laying tile over hardwood stairs steps Flt_Simulation Flooring 12 01-06-2011 08:33 PM
Installing hardwood in adjacent rooms cornish24 Flooring 2 10-26-2010 11:22 PM
