HELP! Insulation Under Carpet Squares??? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-29-2010, 01:22 PM   #1
Question
HELP! Insulation under carpet squares???
I recently ripped up the old carpet in my bedroom. The floors were in worse condition then expected. The gaps between each floor board are fairly large. Some so large that i can see down into the basement. Needless to say, there is a wonderful New England Winter breeze coming up through the floor.
I am using carpet squares for the new carpeting. For now i only have them layed on the floor, they are not adhered. Before i used the adhesive to put them down, i was wondering if there is any sort of insulation i can lay, attach to the floor, then attach the carpeting on top of that. If no such thing, is there some sort of crack filler i can use on the floor to fill those?
Someone please help!!! Its cold!!!
Jduvall1385 is offline   Reply With Quote
Old 01-29-2010, 02:49 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 52
I would put the expandable foam insulation in the cracks and then plywood over the top.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-29-2010, 07:08 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I would be afraid that nasty foam stuff would drip right through and make a helluva mess downstairs.
My suggestion would be to install a plywood underlayment first then use batt insulation downstairs between the floor joists.
There is nothing in the line of insulation you can use on the topside under the carpet squares that would work well and be cost effective.
XXX
Old 01-29-2010, 07:31 PM   #4
i would put roofing felt then ply wood. check with carpet mnfg. for proper install method over ply wood. carpet squares can be cantankerous on some types of underlayment.good luck.
just tile is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Carpeting VS carpet squares captsam58 Flooring 1 12-13-2007 01:11 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
Carpet pad insulation FHBrian Flooring 3 08-31-2006 03:26 PM
