Old 02-15-2009, 08:17 PM   #1
Default Help installing allure flooring trafficmaster yukon tan
I just bought some allure flooring trafficmaster yukon tan from HD and it did not have instructions. I have searched the web but with little luck on how to do it. Or i should say at one point i did find something before I bought it, but did not bookmark the site.
This is 1 foot by 3 foot tiles with the same pattern on each tile.
Question. On the starter piece placed next to the wall, do I need to put something under the glue strip? If I cut it off then the pattern would be missed matched.
Question. Where is Allure homesite for help
Thanks Bill
bill14019 is offline   Reply With Quote
Old 02-15-2009, 08:35 PM   #2
if you did not install it, you might want to return it. Usually you will find some 400 replies to how bad this stuff is.
More On This Topic
Okay, now we're going to put some of the grass in right here and it's going to be sort of a light tan and it's going to be in the distance. So it's going to be sort of a soft, light tan, and there's going to be a village back here so we're going to have... Read More »
One of the best changes or upgrades you can make to your home is adding or changing the tile in your kitchen or bathroom. Before you can begin this type of upgrade, you must first buy your tile. Read More »
Selecting Tiles for Mosaics
Selecting Tiles for Mosaics by Expert Village
There are thousands of different ways to design and make a tile mosaic. For this project I've chosen this Mexican tile as a feature point for our project. Mexican tile has a terracotta backing, so it's a low fire tile. Remember low fire is only good for... Read More »
If you're looking for carpeting you can install yourself consider carpet made in tiles of varying sizes. The major benefit of carpet tiles is the ability to replace only 1 or 2 tiles if staining occurs, while leaving the rest of the carpet intact. Follow... Read More »
So now you've got a bunch of broken tiles, what do you do next? It's time to start positioning them onto your sub straight. There are a couple of things to think about when you're positioning tiles. If you have a shape or a central feature that you're... Read More »
Allure Vinyl Flooring Ash74 Flooring 18 08-17-2009 11:03 PM
Trafficmaster Allure Commercial Confetti Dark Grey Vinyl Flooring (24 Sq. Ft. Per Cas bennyjets Flooring 3 08-10-2009 12:50 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 10:00 PM
Laying Trafficmaster Allure over ceramic tile nhfamily Flooring 0 01-18-2009 09:51 PM
Moisture underneath Trafficmaster Allure flooring kolhoznik Flooring 0 12-20-2008 02:53 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
