Help!!! Hardwood Railroad Tracks.. - Flooring - DIY Chatroom Home Improvement Forum
Old 07-18-2015, 10:28 PM   #1
Rewards Points: 102
Help!!! Hardwood railroad tracks..
How can I get these to look decent again?
I have about 3-4 places where fridge left marks.
FYI...Prefinished 3/4 red oak natural.
Lesha22 is offline   Reply With Quote
Old 07-18-2015, 10:51 PM   #2
Rewards Points: 13,270
Magic Eraser sponge.
Old 07-18-2015, 10:59 PM   #3
Rewards Points: 102
These are indentations not scuff marks.
Old 07-18-2015, 11:09 PM   #4
Rewards Points: 1,200
Many furniture stores, and moving companies use a wax crayon type thing to fill and match dents and dings on their items, maybe you can get some from a cleaning supply place, or maybe a furniture repairman can help you.
ED
de-nagorg is offline   Reply With Quote
Old 07-19-2015, 08:15 AM   #5
Gymschu's Avatar
Rewards Points: 466
I've seen furniture experts remove dents from wood furniture with a moist cloth placed over the dent and then an hot laundry iron placed on top of the cloth. The heat and the moisture cause the wood to expand and the wood fibers return to normal (or closer to normal).
I don't know if it would work on a finished floor with a clear coat on it. You could call your local flooring store to see what is recommended and if the wet cloth/iron trick is something worth trying.
Don't know if this youtube video is pertinent to your situation but it might have some useful info:
Giving us your general location helps us better help you!
Gymschu is online now   Reply With Quote
Old 07-19-2015, 04:59 PM   #6
Rewards Points: 218
Wet cloth ht Iran deal works by forcing moisture not the word at that octagon thus raising the spots.. ignite wokr, might not...and might well end up with something worse than that with which you started.
Leave them be, no me else will notice and you'll stop seeing them too after a while. Reminding me that I still haven't removed and replaced that door molding in the kitchen that I shut too short when I replaced hardwood with tile in the kitchen maybe ten years back or so. Yup, just forgot it again. Ron
ront02769 is offline   Reply With Quote
The Following User Says Thank You to ront02769 For This Useful Post:
Gymschu (07-19-2015)
Old 07-22-2015, 09:33 PM   #7
Rewards Points: 744
Seattle2k is offline   Reply With Quote
Installing new hardwood ontop of existing hardwood benshouse Flooring 4 01-10-2014 01:45 PM
Infested hardwood flooring (how to prevent re-infestation) diyer_12 Pest Control 4 03-18-2012 08:37 PM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 06:15 AM
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 06:50 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
