Old 11-03-2009, 11:36 AM   #1
Angry Help! Fuzz in final poly coat
Yesterday I applied my final (4th) coat of polyurethane (Varethane clear satin) and was ecstatic. I was doing the yippee skippy dance ... until this morning... There are fuzzy pieces embedded in the poly
I used the Varethane applicator pad (lambswool-like) for my project following many recommendations to do so. I had an occasional fuzz in the previous coats, but NOTHING like this time! I should've been recognizing a problem with the pad on the earlier coats (hindsight is 20/20) but it didn't register. Again, it was only a couple in the entire space.
I was extremely meticulous about every step of this project including keeping a clean, dust free environment so I KNOW the fuzz came from the pad.
Now, there are LOTS of these fuzzy suckers!! I see them easily and I'm not happy. I want to correct this today so hoping someone can give advice.
Here's what I'm thinking I should do. Buy a real Lambswool pad applicator. Sand, vacuum, tack off and apply another coat of poly. I'm assuming there will be no problem having 5 coats of poly instead of 4... maybe just longer dry/cure time. By the way - I'm thinking 7 days dry/cure time before moving furniture back into the room. Is this enough time?
If there is a better or easier way to fix this I'd love to hear from you. Thanks so much!! Rox
Here's a pic:
roxksears is offline   Reply With Quote
Old 11-03-2009, 03:04 PM   #2
Update..
I just got back from Lowe's.. told them about my fuzz situation. The fella that had helped me in the past got his manager involved who said, yeah these pads tend to fall apart after you clean them. If that is the case it should be labeled "one use only"! The fella got his manager to give me 100% lambswool pad no charge as an extension of his apology which was nice of them.
So... I'll sand and give it a 5th coat. Keep your fingers crossed for me!
Old 11-03-2009, 03:19 PM   #3
It is possible to get too many coats on your floor, so be sure to stretch this top coat. With your new lambs wool, take your wifes hair or a cat brush & brush the excess lambswool fibers out before you use it. Then, take some duct tape & tack off the remaining fibers. My next piece of advice would be to thin your top coat of finish between 10-15% naptha. You'll be amazed at how much better that little step will make your floor. Really flows out the finish super smooth.
pinwheel45 is online now   Reply With Quote
More On This Topic
Hey kids, Doctor Drink back with you. Drink team in action in Austin. Texas, that is. We've got Billy Beer back here, he's back vertical. Last time you saw him he may have been unconscious, I'm not sure, he may have been playing a little possum. Playing... Read More »
Once you've time sliced your sample and you have a new program for that time slice and you've switched all to one-shot you're going to notice that when you play your sequence in order it's going to overlap each other. So, to solve this problem we're... Read More »
Hi! I’m William Myers from Austin Subaru for Expert Village and I’m going to show you the underside of your Subaru. Okay we’re going to talk about a few components here, now that the tire has been removed you can see a few things. You... Read More »
Hi, I'm Marti with expertvillage.com today I'm going to show you how to iron a tablecloth. Just remember if you are ironing around young children or pets, use certain precautions. One precaution I like to use is my silicon pad. I got this at a craft... Read More »
Alright, so here we are, we're just waiting for the resin to cure. And like I said, this UV-resin, this is about fifteen to twenty minutes later and you can already see that you can't even put a nail mark in there which means that the resin is doing... Read More »
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 08:57 AM
metal left in hardwood floor sealer deetu Flooring 24 01-06-2009 05:11 PM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 08:23 PM
Finishing Cabinets -- Wow. Need advice! dsteinke Painting 15 08-09-2007 11:55 PM
Mudding Finish Is Showing on Final Coat Hages Painting 7 03-20-2007 12:09 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
