Help! The Floor Board Under Carpet Stinks - Flooring - DIY Chatroom Home Improvement Forum
Old 05-04-2013, 10:27 PM   #1
Question
Help! the floor board under carpet stinks
I want to replace the carpet as I am renovating. However, I have a smelly issue with the floorboards under the (now) removed carpet. I believe the board is masonite or MDF, and I removed the carpet and underlay as it smelled of mildew. The smell is still within the boards, and I have left the room to 'breathe' for 4 weeks but the boards still smell. Does anyone know what can be done, as the room is unlivable with such an odour?
Miss C is offline   Reply With Quote
Old 05-05-2013, 04:40 PM   #2
Too Short? Cut it Again!
If they are dry, you might try a primer like BIN. It is an alcohol based product (so use plenty of ventilation) and commonly used for sealing in odors such as in homes where heavy smokers have tainted walls and ceilings.
Some have used Zinsser Cover Stain. It is oil-based primer.
Note that primers are not really meant for floors but in this instance, if padding and new carpet is going over them it might work out. You may have to put a moisture barrier down but then you reduce the ability of the floor to breathe and you may cause a worse situation long term.
Obviously you should source the source of the moisture that is causing this or anything you do is likely to be temporary.
You might ask your real flooring company or real paint store for recommendations. You will just get a "deer caught in the headlights" look at a box store.
The Following User Says Thank You to user1007 For This Useful Post:
Miss C (05-10-2013)
Old 05-05-2013, 04:56 PM   #3
Floor Installer
sam floor's Avatar
Rewards Points: 154
Kilz or plain shellac will kill the odors but won't help with moisture.
sam floor is offline   Reply With Quote
The Following User Says Thank You to sam floor For This Useful Post:
Miss C (05-10-2013)
Old 05-05-2013, 06:10 PM   #4
Rewards Points: 3,528
If it's masonite or mdf pull it up and replace it,you'll never get rid of the smell.
Canarywood1 is offline   Reply With Quote
The Following 3 Users Say Thank You to Canarywood1 For This Useful Post:
Dave Sal (05-10-2013), joecaption (05-11-2013), Miss C (05-10-2013)
Old 05-10-2013, 10:58 PM   #5
Thanks for everyone giving me ideas! I am in Australia, so I don't think we have the same name brand stores/ and or products....but all ideas are helpful! Thanks to you all :-)
Tags
carpentry , damp , floor , floorboards , mildew
Couple carpet questions ponch37300 Flooring 8 09-28-2012 02:30 PM
Flooring Under Carpet Mstrenke Flooring 4 06-24-2012 05:54 PM
Carpet Flooding and Replacement airjay81 Flooring 1 05-08-2012 12:00 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
