Help With Damaged Engineered Hardwood - Flooring - DIY Chatroom Home Improvement Forum
Old 07-13-2009, 06:49 PM   #1
help with damaged engineered hardwood
I am a college student and we have 2 weeks before our lease is up. We live in a townhouse and parts of our floor started to bubble up along the seams . Is there any way to replace the damaged sections? They are telling us that we have to pay to have the entire floor replaced. We had no clue that you couldn't mop it they never told us that, and I know that other units have had problems as well. Any help would be appreciated, and I believe it is not glued it is a floating floor.
ddrach is offline   Reply With Quote
Old 07-14-2009, 04:43 AM   #2
Engineered hardwood floors and water
Unfortunately engineered hardwood floors do not do well with exposure to water. Without seeing pictures it is hard to say for certain but it is likely that some sections of the floor are permanently damaged. However if you can find flooring that exactly matches what is there then it should not be necessary to replace it all. However, that may not be possible, especially if the floor is aged. In this case you may have to pay for the floor to be replaced. If that does happen make sure they do not charge you for a better quality floor than what is already there.
TopTipper is offline   Reply With Quote
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 09:23 PM
poly on engineered hardwood floor? Constant Improvement Flooring 3 02-03-2009 11:09 AM
can engineered hardwood be a floating floor? smythe01 Flooring 10 07-09-2008 10:16 PM
Quality of Pergo engineered HARDWOOD? Jeff12 Flooring 2 01-13-2008 09:17 PM
old termite damaged hardwood Kbotard Flooring 8 05-14-2007 02:22 PM
