Help Best Flooring Choice Needed - Flooring - DIY Chatroom Home Improvement Forum
Old 01-28-2011, 11:46 PM   #1
Help best flooring choice needed
Hi all really need best recommendation for flooring New construction walk out basement concrete floor 3 season cottage will be well below zero in winter. Carpet not an option would be high traffic 3 kids 3 dogs
Sellwithnic is offline   Reply With Quote
Old 01-29-2011, 08:02 AM   #2
woodman58's Avatar
Porcelain tile it is freeze thaw stable, or a ceramic that is freeze thaw stable, Sheet Vinyl, Commercial vinyl tile (not peel and stick)
woodman58 is offline   Reply With Quote
Old 01-29-2011, 09:30 AM   #3
Now what would you recommend as a sub we were looking at a all in one product from superseal.ca I like the sheet vinyl idea or the ceramic we are trying to do as much ourselves if possible
Old 01-29-2011, 07:10 PM   #4
woodman58's Avatar
You cannot use the All in One By Superseal. If you go to their web site it says it is for laminate and carpet. You can go over the concrete with vinyl or ceramic. Just make sure it is freeze thaw stable. Do a moisture test over the concrete before installing either product. You can do this by taping a peice of plastic (3 feet by 3 feet) down to the concrete. Leave it there for a week. See if there is any moisture that collects under it. If moisture is present you will need to put a sealer on the floor. If you choose ceramic, it is not hard to install yourself. Do a search on "How to install ceramic. Read alot of different sites. Some are good, and some are bad. Take all of your reading knowledge and put the best parts into putting your new floor down.
Make sure and pull your base and use a hand saw to under cut the doors. Do this by laying a peice of the cardboard box the tile comes in under a peice of tile. This will give the hight you need for the tile to go under the jam. Push the hand saw flat to the tile to cut.
Old 01-29-2011, 09:27 PM   #5
Should I just put a sealer down anyway? Better safe then sorry type deal. I have done some tiling in past with goods results this is a cottage just wanted something easy lol
Old 01-29-2011, 10:37 PM   #6
woodman58's Avatar
It won't hurt to put the sealer down.
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 09:53 PM
Laying solid oak flooring...advice needed. splinters Flooring 5 04-11-2010 08:11 PM
Konecto flooring LookoutRanch Flooring 23 03-08-2010 04:32 PM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 08:06 PM
Choice on flooring, need some input... christalynn11 Flooring 2 02-11-2009 09:15 PM
