Help! Backfilling A Closet - Flooring - DIY Chatroom Home Improvement Forum
Old 09-13-2011, 08:58 PM   #1
Help! Backfilling a closet
Hey guys,
I need a little help. I'm currently laying 3/4" maple hardwood flooring in the upstairs of my home. I've reached a part and I'm not sure what to do. I know I need to backfill the closet and I know I need a spline to change the direction of the wood. What I'm unsure of is how to make sure the piece of wood that is the "change of direction piece" is straight. I've attached a picture to hopefully explain it better.
Thanks in advance for your assistance.
JTAP is offline   Reply With Quote
Old 09-13-2011, 09:19 PM   #2
Experienced
Jackofall1's Avatar
You should have established a string line to mearsure from, this line would have been established out from your starting wall and used as a reference line across the room.
You may find that when you get to the opposite side the floor is straight, but the adjacent wall isn't.
Mark
Old 09-13-2011, 09:29 PM   #3
Mark,
Thanks for your reply. My starting wall was in the hall and I have just ran the flooring straight through the doorway into the bedroom so I don't have another reference line. I should have put that in the original post....sorry .
I can't figure out how to make sure that the board that runs parallel to the closet is straight. What wall should be my reference?
Thanks again
Old 09-13-2011, 09:37 PM   #4
Experienced
Jackofall1's Avatar
The line you ran in from the hall is the line that you are going to reference, those boards have to stay straight with their point of origin.
You don't have any choice other than minute adjustments once you have established the line into the room.
Mark
Framing a new header for closet opening jmai14 Carpentry 6 07-09-2011 02:20 PM
Laundry closet decision LClark Remodeling 2 06-26-2011 06:19 AM
Closet motion lights gmhammes Electrical 24 03-03-2011 07:53 AM
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 04:42 AM
Musty smell from closet after leak Musty General DIY Discussions 2 09-10-2007 08:36 PM
