Help! Armstrong "luxury" vinyl tile installation
well I gave in and put the floor down... the tiles are "self stick pressure adhesive" but when you peeled the paper off it was dry as it could be and I thought even if its pressure sensitive to sticking, I am going to help it with a laid down adhesive... went out got the glue for it that Armstrong recommended, did it in 4 sections... put the glue in the farthest corner, let it sit for 30 minutes like it said until tacky but no glue lift... laid the tile like it was ceramic or stone... pushed it down with a rubber mallet to help it along, then rolled it some to push out the bubbles and help the glue to stick... did the whole floor, grouted it with the suggested sand based acrylic "luxury vinyl tile floor grout" and when you look at it you cannot tell it isn't a slate tile that is until you step on it and realize it’s not stone because it is of course softer and warmer then stone... but for the cost defiantly would recommend these premium tiles from Armstrong, might take longer then rolling out a linoleum sheet, but defiantly worth it for appearance if you add the extra glue in the mix
