Old 03-20-2008, 10:57 PM   #1
Hello - Laminate Flooring Help
I am a new participant and look forward to learning and sharing with all of you.
I plan to install laminate flooring over a 'slab' concrete subfloor. The floor is in excellent shape - no moisture and level. I was told to use Dream Home Insulayment under the glue down flooring. Does this sound correct? Also, should I spread a moisture barrier on the concrete before I lay the insulayment?
Senior Homeowner is offline   Reply With Quote
Old 03-20-2008, 11:07 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Welcome to this great web site. Glad you joined.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 03-21-2008, 06:01 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Hi and welcome to the site.
- Build Well -
Old 03-23-2008, 09:14 PM   #4
Wood Flooring & Carpentry
lawndart's Avatar
Are you installing a Laminate floating floor, or a glue down engineered floor?
lawndart is offline   Reply With Quote
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
laminate v. hardwood flooring JDuc Flooring 11 01-13-2008 10:01 AM
Laminate Flooring Outdoors fogel1497 Flooring 1 05-28-2007 04:39 PM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 09:35 PM
Laminate Flooring Question cacell Flooring 6 03-03-2006 06:44 PM
