-   -   Hello - Laminate Flooring Help (http://www.diychatroom.com/f5/hello-laminate-flooring-help-18771/)
Senior Homeowner 03-20-2008 09:57 PM
I am a new participant and look forward to learning and sharing with all of you.:)
I plan to install laminate flooring over a 'slab' concrete subfloor. The floor is in excellent shape - no moisture and level. I was told to use Dream Home Insulayment under the glue down flooring. Does this sound correct? Also, should I spread a moisture barrier on the concrete before I lay the insulayment?
Ron The Plumber 03-20-2008 10:07 PM
Welcome to this great web site. Glad you joined.
AtlanticWBConst. 03-21-2008 05:01 AM
Hi and welcome to the site.
lawndart 03-23-2008 08:14 PM
Are you installing a Laminate floating floor, or a glue down engineered floor?
