Heavy Joist Span Tables - Flooring - DIY Chatroom Home Improvement Forum
Old 08-04-2011, 05:56 PM   #1
Heavy joist span tables
Where can I find joist span tables for heavy cut timber joists. Like 4x14 joists. It is for a large log home that is 40 x 40. It has a log girder across the middle giving 20' spans. An engineer told me 4x14 that are 32" oc. It has 2x6 T&G decking on top. I can find any tables to check myself.
rvr600 is offline   Reply With Quote
Old 08-04-2011, 09:11 PM   #2
Civil Engineer
Rewards Points: 4,520
I am not aware of tables for large format beams. I use a spreadsheet I developed based on fundamental mechanical properties, which I use frequently for a wide range of lumber sizes. Perhaps you should discuss the matter with your engineer, when you get into large size wood beams there are certain considerations such as proper connections that are outside the realm of standard code, and require careful design.
Center bearing vs. Clear Span floors -- Span Tables WaldenL Building & Construction 2 02-24-2015 07:50 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 09:00 AM
How to calculate Joist span table for 3x8's WillSTX Building & Construction 22 03-19-2010 05:41 PM
Max span length on 4-2x10 fir beam? gadget463 Building & Construction 4 08-03-2009 06:51 PM
