Heavy Dust & Tongue & Groove Ceiling Fix - Flooring - DIY Chatroom Home Improvement Forum
Old 11-07-2008, 06:49 PM   #1
My new home is a two-story. The first floor is all Pergo and the downstairs is all tongue and groove ceiling. Throughtout the day as people walk upstairs the dust falls and falls and falls. A thick coat of dust is present each and every day.
I need a way to seal the T&G above my office where computers and other senitive electronics reside.
A polyurethane sealant was recommended as a "possible" solution. I don't know the difference or if this is even the solution.
bobricci is offline   Reply With Quote
Old 11-08-2008, 08:15 PM   #2
Get out of the box!
Rewards Points: 260
Are you saying you can see the overhead flooring from the computer room?
Is there is no ceiling?
I would start with your air filter, check it first.
26yrsinflooring is offline   Reply With Quote
Old 11-08-2008, 08:20 PM   #3
I cannot see the flooring from upstairs. What I can see is unsealed T & G above me. The dust is extreme and thick each day -- an air filter might help the symptom, but I'd like the cure
Old 11-08-2008, 08:29 PM   #4
Get out of the box!
Rewards Points: 260
In thoery there should not be any dust coming from the under the Laminate if they used the proper underlayment...in thoery...
It will hard to apply poly to a ceiling.
Here is a time consuming idea for a fix: Run a color match caulk in the joints between the boards. It will take longer than the Poly attempt but you will not be fighting the gravity issue that you will face with poly.
Old 11-08-2008, 08:47 PM   #5
That sounds like a great idea. I can tell you that the workmanship is not the greatest. I have seen worse, but some of this is just sloppy. I don't know what is above the T & G but will give the caulk a go.
Tongue and Groove Ceiling install....questions... Dr. Jim Remodeling 9 04-08-2012 12:14 PM
Tongue and groove miami vice 25 Flooring 8 04-04-2012 06:35 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Wooden Tongue & Groove Soffits Beverlyb Roofing/Siding 2 08-30-2008 10:31 AM
tongue and groove fence pickets - bad idea ? JoeT Carpentry 6 05-23-2008 11:00 AM
