Heated Tile ... Really Worth It? - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-09-2009, 03:00 PM   #16
I've been doing reading on heated tile, as i hope to install it within the month, but my question is - Do I have to put it on it's own circuit? how much juice do these things really use? I'm a single guy with the hopes of soon having a wife that would be using a curling iron/hairdryer/whatever else they use... This stuff would all be on the same circuit along with the lights... good idea or bad idea?
thanks!
greenvorlon is offline   Reply With Quote
Old 01-09-2009, 03:04 PM   #17
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Bad idea!
Some of those heat systems don't require a separate circuit but it is always advisable to dedicate a circuit to a floor heat system.
Old 01-09-2009, 03:06 PM   #18
K&B Remodeler/Tile Guy
angus242's Avatar
The heating mat itself will come with requirements. You should assume it would need its own circuit. Some larger ones even require 220V.
Building codes in your area will override whatever the heating mat itself states.
Angus
My Albums
angus242 is offline   Reply With Quote
Old 01-10-2009, 02:41 PM   #19
Remodeling Contractor
the heat mats are manufactured with a reflector at the bottom. The heat is directed into the surface above. And this surface is heated and this heat then rises. It is actually a very cost effective and efficient heat. I modified my entire heat in the house to radiant heat system. And cold tile? Why not go milk the cows and cut some more wood for that damn fire, if you really want your wife to live in the pioneer times.
Old 01-10-2009, 05:10 PM   #20
angus242's Avatar
The latest question was about connecting an electric heating mat to the current bathroom circuit, not about their performance.
Angus
My Albums
Old 01-10-2009, 05:15 PM   #21
Electrician
Originally Posted by Bud Cline View Post
Bad idea!
okay, i'll bite, why would it be a bad idea?
chris75 is offline   Reply With Quote
Old 01-10-2009, 07:51 PM   #22
The typical things in a bathroom, like a hair dryer take enough power to require their own circuit. This is why it is a bad idea to add more to this same circuit.
Old 01-10-2009, 09:18 PM   #23
Electrician
Who said anything about sharing the bath receptacle circuit?
Old 01-11-2009, 08:51 AM   #24
the original post indicates that we wanted to know why he cannot tie to the existing circuit. In old houses the lights and plugs are all on one circuit.
Old 01-11-2009, 08:56 AM   #25
Electrician
Okay, I probably took your post as is, and was not following along.
Old 01-11-2009, 12:04 PM   #26
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Select a heating product then read and follow the directions. It's as simple as that.
Mariani: Not all heat systems of this type have the reflector, in fact, most don't. Heat rises naturally.
Old 01-11-2009, 12:31 PM   #27
Electric Radiant Heating
warmsmeallup's Avatar
Rewards Points: 150
Um..actually, hot air rises, heat goes to cold. If an infloor radiant system is installed on a first floor and the basement below is colder than the first, the heat will radiat downward.
www.comfortradiant.net
warmsmeallup is offline   Reply With Quote
Old 01-11-2009, 12:35 PM   #28
yes radiant heat works much differently than other heat sources and does not work by rising air.
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
heated tile but over hardwood... canadaclub Flooring 3 02-08-2008 05:26 PM
20" Porcelain Tile with heated wires - Please help! jmille72 Flooring 3 11-29-2007 08:38 AM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
