Heated Tile But Over Hardwood... - Flooring - DIY Chatroom Home Improvement Forum
Old 02-05-2008, 04:31 PM   #1
Handyman
Rewards Points: 512
heated tile but over hardwood...
Hi all. Just wondering about installing radiant heating under ceramic tile (kitchen and small bath area). Problem is the floor is currently hardwood. Would it be best to remove the hardwood and tile over the subfloor? or is a backerboard necessary and also is it compatible with the radiant heat mats?
Thanks all,
CC
canadaclub is offline   Reply With Quote
Old 02-05-2008, 10:13 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Get rid of the hardwood.
Install the heat. Then bury it in Self Leveling Compound which would also serve as your tilebacker.
There is other criteria to consider but in a nutshell this is the easiest way to do it with the best assurance.
Old 02-08-2008, 04:15 PM   #3
Handyman
Rewards Points: 512
Thanks Bud. Isn't it awful how the real answer is always the most difficult! lol. Someone is telling me that I need a min. 1/2" plywood subfloor for heated tile...is that true?
Old 02-08-2008, 05:26 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
There are several things to be considered. My guess is that suggestion is if you intend to install tile over the hardwood and I'm hoping that isn't the case, it is very risky.
A sufficient floor structure is required for tile and the subfloor should be 1-1/8" thick before the tile, but yours isn't going to be that thick after the hardwood is removed. Some of that thickness would be/could be cement backerboard for the tile.
ANYWAY.........
What is the floor criteria now?
What size are the floor joists?
How far apart are the floor joists spaced?
What is the unsupported span of the floor joists?
What is the subfloor made of and how thick is it?
If they are talking about a 1/2" thick subfloor on the joists I doubt that is the case, that wouldn't meet any building codes for the past fifty years.
Hardwood and Tile Transition Gap mobowhunter Flooring 2 01-19-2008 05:25 PM
20" Porcelain Tile with heated wires - Please help! jmille72 Flooring 3 11-29-2007 08:38 AM
Hardwood Or Tile? ImFlippinCrazy Flooring 11 04-25-2007 03:56 PM
hardwood floor vs ceramic tile vs puppy Burat Flooring 12 03-31-2007 03:56 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
