Heated Floors Affecting Grout Question - Flooring - DIY Chatroom Home Improvement Forum
Old 12-03-2008, 03:24 PM   #1
Heated Floors Affecting Grout question
I am considering putting in electric heated floors in a soon to be re-tiled bathroom. However, one store recently told me that when the heated floors heating element is turned on and off via a thermostat, that the grout will deteriorate. Is that true? Do others have any experience with this question? Thanks.
Ted Uy is offline   Reply With Quote
Old 12-03-2008, 05:13 PM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
I've never seen any sort of issue like that. The element is set in a concrete mix. Tile and grout doesn't expand and contract like wood does. I can't see why this would effect the grout. It's not like a freeze/thaw situation. If you are that worried about it use a grout Called Quartzlock. It's a quartz crystal suspended in an acrylic resin instead of your standard cement grouts. It's a bit more flexible than normal grout plus it's stain resistant.
poppameth is offline   Reply With Quote
Old 12-04-2008, 09:48 AM   #3
Heated Floor Grout Question
Thanks very much for your reply and suggestion.
Old 12-04-2008, 02:16 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
BALONEY!!!
I have dozens of heated floors under my belt and have never once had an issue with any of them. Regular cement grout works just fine. Bury the heat system in Self Levelling Compound and you won't have any worries.
Old 12-04-2008, 03:01 PM   #5
Floorwizard's Avatar
No doubt.
What wierd advice.....
Floorwizard is offline   Reply With Quote
Old 08-28-2009, 12:12 PM   #6
If only that were true
Originally Posted by Bud Cline View Post
BALONEY!!!
Maybe you should of installed mine then. The contractor did a nice enough job and the heated floor isnt an issue - However all the grout began to crack after a few months with the first season change - it's all nearly broken now. The winters are fairly mild as well. So now I plan on doing it over myself - I will try the quartzlock.
sirusdoo is offline   Reply With Quote
Old 08-28-2009, 01:06 PM   #7
Rewards Points: 109
Grout cracking likely has to do with your underlayment quality and structure and not your heated mats.
BimmerRacer is offline   Reply With Quote
Old 08-28-2009, 02:04 PM   #8
That sounds worse
So you think the tile was laid on un-level floor?
Old 08-28-2009, 02:15 PM   #9
Rewards Points: 109
No, I don't think that, but tile has specific requirements for underlayment and support structure as established by TCNA. My house, for example, didn't meet the requirements for stone, let alone for ceramic tile and I had to do a lot of work to get it there.
Good read
http://www.schluter.com/5138.aspx
Old 08-28-2009, 04:44 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Your floor-heat-system IS NOT the cause of your cracking grout.
XXX
Old 08-28-2009, 05:01 PM   #11
Quadfam4's Avatar
must have been one of those HD guys giving advice again.
Quadfam4 is offline   Reply With Quote
Old 08-29-2009, 06:57 AM   #12
Remodeling Contractor
Home Depot gave bad advise? The issue is caused by too much deflection in the floor. As several posted correctly the grout and heat mats are not your problem.
Old 08-29-2009, 12:45 PM   #13
wow...old post brought back to life.....
Grout question poolecw Flooring 11 10-29-2008 07:32 PM
What works and what doesn't to clean grout? groutresearcher Flooring 2 09-04-2008 10:49 PM
another grout color change question tryinitmyself Flooring 1 02-22-2008 06:50 PM
Grout question rick32 Flooring 1 11-21-2007 03:19 PM
Laying Wood Floors - subflooring question drewz Flooring 8 09-21-2007 08:56 AM
