Heated Floor Under Engineered Hardwood? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-26-2012, 12:38 PM   #1
heated floor under engineered hardwood?
Is there anyone with experience on putting engineered wood flooring in a bathroom - and with heated flooring underneath?? Thinking of running my wood right through into the bathroom from the new bedroom addition.
Any comments would be appreciated.
Gecko is offline   Reply With Quote
Old 03-26-2012, 01:57 PM   #2
Pro
JetSwet's Avatar
Rewards Points: 502
I wouldn't suggest any wood type in the bath area and I think I won't be alone in my opinion on this.
You can get tile that looks like wood that will work especially for heated floor.
JetSwet is offline   Reply With Quote
Old 03-26-2012, 02:03 PM   #3
Rewards Points: 13,994
Ageed no form of wood would be a good idea.
JetSwet (03-26-2012)
Old 03-26-2012, 09:24 PM   #4
My grandmother put wood floors in her bathrooms and my brothers and sister like to screech "wipe up the floor after you take a shower" when we want to remember her.
MissKat is offline   Reply With Quote
Old 03-27-2012, 07:17 AM   #5
floors
Thanks for the opinions, but it's just me here and would be controlled as far a "water" on the floor.........no different then my wood floors in my kitchen and when the mop bucket is accidentally tipped, you just wipe it up quickly........never had damage in all the homes I've had with wood in the kitchen. Still undecided, but might end up going with ceramic as may put a wet steam in the shower and then it would be too much humidity for the wood.............
Old 03-27-2012, 07:21 AM   #6
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 146
Ask the manufacturer before you put engineered over in-floor heat. See what they think.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 03-27-2012, 08:26 AM   #7
Floor
Thanks, already asked and many of the engineered floors can accept the heat beneath...........
Old 03-27-2012, 08:30 AM   #8
Rewards Points: 146
Then do it.
Old 04-02-2012, 04:10 PM   #9
I don't care what any of these manufacturers say about it, this type of flooring is NOT good for wet areas. I learned the hard way.
Use a good ceramic or something like that if you want to heat the floor. I know that works.
Janetp is offline   Reply With Quote
hardwood on engineered floor? kalpi Flooring 1 09-27-2011 06:32 PM
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 09:23 PM
Dricore and Engineered Hardwood doughboy52 Flooring 0 06-23-2010 08:45 AM
Engineered Hardwood: Inlaid transition? SteveSmith98 Flooring 6 03-24-2009 11:21 AM
can engineered hardwood be a floating floor? smythe01 Flooring 10 07-09-2008 10:16 PM
