Heat Mat & Ceramic Tile In Bathroom - Flooring - DIY Chatroom Home Improvement Forum
Old 02-18-2013, 02:21 PM   #1
heat mat & ceramic tile in bathroom
hi, i want to put a heating mat with ceramic tile in my bathroom. if the sub floor is good plywood can i put the mat right to the plywood then tile or do i have to use backer board? i was also told i can us a fiber material also over plywood subfloor to eliminate cement board? has anyone heard or used this method? ive looked on the internet at videos & have seen it done different ways from thinset to self leveler, put thinset then mat let dry then more thinset & tile. others put down mat thinset and tile all at once? does it matter? confused.
jpaz is offline   Reply With Quote
Old 02-19-2013, 11:08 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
I would apply the mat to the floor and embed it in either thinset of self leveling compound (use the primer before the mat if you use SLC) then apply a layer of Ditra membrane of this before tiling. It's covered in the Ditra installation handbook.
Darkling Designs
poppameth is offline   Reply With Quote
Removing Bathroom Ceramic Tile Laid in 1970 mark2741 Flooring 6 12-08-2011 09:55 AM
Ceramic tile over asbestos tile question MLMIB Tiling, ceramics, marble 4 01-10-2011 08:58 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 09:50 PM
Type of Tile for Basement Bathroom MrBill_DIY Flooring 1 05-02-2010 04:08 PM
