Originally Posted by lleegle
No I did not check the moisture...I actually dont know anything about installing hardwood floors (is this obvious??heh)...It was a project that started as something simple...and then progressed to something much more complicated.....The wood had been in this room for about 6 months before I even began installing it. I am in Alabama however..and you can cut the humidity here with a knife.
Is there anything that I can do?....should do?....What will happen if I proceed with the current situation?..
Thank you so much for your time.
Leigh
How exactly did you apply the stain? If you used a brush, the haze you are looking at could be from uneven brush strokes.
If I were you, I'd seek the advice of a local hardwood professional. Sometimes, it's worth the money to have the job done right the first time. Some projects are just too much for DIY'ers.
