Hi, I just purchased the laminate flooring from costco. The flooring already has a thin pad on the bottom of each piece. Question is, if it is still recommended to put extra padding on the floor before laying the laminate flooring which already has padding. I talked to HomeDepot people and they said it is not necesary. That if I do put the padding it will be to bouncy and that you need just enough padding to muffle the sound.
What are the pros and cons in adding extra padding.
Thank You
Thank You
