-   -   Harmonics Vintage Chestnut from Costco (http://www.diychatroom.com/f5/harmonics-vintage-chestnut-costco-31316/)
chompis 11-06-2008 02:35 PM
Hi, I just purchased the laminate flooring from costco. The flooring already has a thin pad on the bottom of each piece. Question is, if it is still recommended to put extra padding on the floor before laying the laminate flooring which already has padding. I talked to HomeDepot people and they said it is not necesary. That if I do put the padding it will be to bouncy and that you need just enough padding to muffle the sound.
What are the pros and cons in adding extra padding.
Thank You
Marvin Gardens 11-06-2008 04:32 PM
I just installed that exact laminate.
No need to put anymore padding. Too much padding will make it too spongy and put stress on the connection between pieces.
I found the padding already attached to be just right.
Floorwizard 11-06-2008 05:22 PM
Marvin is correct.
chompis 11-06-2008 05:54 PM
Thank You
You saved me some money. I was about to buy the padding yesterday. Thanks Again
Marvin Gardens 11-06-2008 06:01 PM
We seem to do that a lot. :yes:
