Old 03-18-2009, 10:16 PM   #1
Default Hardwoods up to exterior door
The room where I plan to lay hardwoods has two exterior doors. Is there a proper way to run the hardwoods up to an exterior door, or do you just run it right up the edge under the thresh hold?(with 1/2" gap of course) I guess I am thinking of how it will achieve a "finished look".
pancakes is offline   Reply With Quote
Old 03-19-2009, 02:45 AM   #2
Do yourself a favor... don't run the wood up to the threshold.
Many times I've had customers with existing wood floors call me to look at damage with an eye to fixing it.
Where I typically see problems with wood floors are kitchens, baths, utility rooms, and entries.
Moisture finds its way in at the threshold and typical issues are; delamination, dark streaks (fungal growth), cupping, crinkled finish, and gaps where swelled planks compressed eachother's edges that later dried out.
The typical solution at entries is to cut out the damaged area and replace it with ceramic tile or some other water-resistant flooring.
So, just do it that way from the get-go.
Mudd is offline   Reply With Quote
More On This Topic
Hi, this is Jon, and in this clip we'll be gluing the threshold. At the bottom of our door we have have our threshold, and before we install our door we need to put some construction adhesive underneath the threshold, and that's going to help hold that... Read More »
Hi! my name is Brandon and I work at BC Surf-n-Sport here in Coral Springs, Florida. You can find us on the web at www.bcsurf.com. Today I am going to tell you how to maintain a skateboard. Mainly just make sure you don’t want your board in the... Read More »
Installing a Door Threshold
Installing a Door Threshold by Expert Village
We’re installing a back door threshold. Now in this one, we’re going to have to install an oak board. You want to make sure that that is oak so that it won’t rot away. And this slab slopes inward, which has caused a lot of problems with... Read More »
Hi, this is Jon and in this clip we will be removing our door. Now that we have cut all of our nails that is holding our door in place, the door is loose and we're ready to completely remove it. Now taking a look at the threshold on the bottom of the... Read More »
My name is Paige and today we are talking about the best way to clean your wood floors. There are several steps to cleaning your wood floors. What you want to do first is vacuum; sweep your baseboards on your wood floors picking up all the particles that... Read More »
Getting ready ro refinish my hardwoods, I would like to add to it as well... J187 Building & Construction 23 02-27-2009 02:58 PM
removing glue from hardwoods david81 Flooring 2 05-24-2008 12:37 PM
Removing Tile for Hardwoods ATLDIY Flooring 0 04-24-2007 12:31 PM
Refinishing hardwoods J187 Flooring 2 10-26-2006 12:35 PM
Are all hardwoods (flooring? created equal??? ahnniem Flooring 2 01-28-2006 03:17 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
